Kyocera Event Ear Piece Speaker Replacement
  1. Kyocera Event Ear Piece Speaker Replacement, Battery: step 1, image 1 of 3 Kyocera Event Ear Piece Speaker Replacement, Battery: step 1, image 2 of 3 Kyocera Event Ear Piece Speaker Replacement, Battery: step 1, image 3 of 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Ear Piece Speaker Replacement: step 2, image 1 of 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Ear Piece Speaker Replacement, Remove the screws.: step 3, image 1 of 2 Kyocera Event Ear Piece Speaker Replacement, Remove the screws.: step 3, image 2 of 2
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  4. Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: step 4, image 1 of 3 Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: step 4, image 2 of 3 Kyocera Event Ear Piece Speaker Replacement, Remove the back assembly: step 4, image 3 of 3
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
  5. Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: step 5, image 1 of 3 Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: step 5, image 2 of 3 Kyocera Event Ear Piece Speaker Replacement, Ear Piece Speaker: step 5, image 3 of 3
    • Soldering required to complete replacement
    • Start by un-attaching the small olive colored chip from the plastic casing.
    • The chip is connected to the phone by a small orange wire. Keep the wire connected to the chip and the phone body while removing the chip from the black plastic casing.
    • Pry underneath the chip with the plastic opener until it pops off. Leave the orange wires attached.
  6. Kyocera Event Ear Piece Speaker Replacement: step 6, image 1 of 3 Kyocera Event Ear Piece Speaker Replacement: step 6, image 2 of 3 Kyocera Event Ear Piece Speaker Replacement: step 6, image 3 of 3
    • Use tweezers to lift up the black plastic cover.
    • The cover will pop out. Set it aside.
  7. Kyocera Event Ear Piece Speaker Replacement: step 7, image 1 of 3 Kyocera Event Ear Piece Speaker Replacement: step 7, image 2 of 3 Kyocera Event Ear Piece Speaker Replacement: step 7, image 3 of 3
    • Speaker is magnetized.
    • Use a metal object to lift the speaker out OR use tweezers to grab underneath the top corner of the speaker and lift/pry it out.
  8. Kyocera Event Ear Piece Speaker Replacement: step 8, image 1 of 1
    • Unsolder the speaker wires from the phone.
2 other people completed this guide.
cmiller24
19 Reputation
1 Guide authored
Ohio State, Team 1-2, Michaels Spring 2015 Member of Ohio State, Team 1-2, Michaels Spring 2015
OSU-MICHAELS-S15S1G2
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 835
