Introduction
This guide will explain how you can replace the battery cover on your Kodak Easyshare Z981.
Open the battery cover and remove the AA batteries from the camera if any are inserted.
Tool used on this step:Phillips #00 Screwdriver$5.49
Use a 00 Phillips-Head screwdriver
Remove the 3 mm screws from the camera.
Four (4) screws are in the bottom of the device
Four (4) screws are inside the battery cover
It isn’t the back cover which is defalse but the 3 plastic pin which the battery cover open and close. Does this part must be change.
This is my koday mode KKL-Z981(B)
It is’nt the back cover which is defalque but the 3 plastic pins on which the cover open or close to charge or remove the battery.Thank’s
Does this piece be replace ?
Where can I buy the bottom panel
Remove the bottom of the battery cover first, and then the top.
5 other people completed this guide.
6 Comments
where can i buy it?
PLEASE help? I can't find this part anywhere?
I HAVE THE SAME QUESTION. WHERE ARE THE PARTS BOUGHT??????? WHY PUT THIS OUT IF U CAN’T BUY THE PARTS?? bILL RENTMRBILL@YAHOO.COM
my clips broke on my battery door so I bought another camera (same) to replace the whole bottom, but cannot find a way to do it. So now I have 2 broke cameras.
July 10, 2022.. If your door to your Kodak Z 981 will not stay shut, attach your Vertical Picture Grip to the bottom of the camera. That will keep the battery cover shut. It is a pad that attaches to the bottom of the camera so you can turn the camera side ways to take vertical shots . Buy a used one if you do not have one.
Glenn Cochran - Reply
