Introduction
This tutorial demonstrates how to remove the back cover from the camera.
Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
Apply pressure on the left and right side of the camera and pull the back cover away from the device.
Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
