Introduction
If your kitchen extractor fan motor is humming or running very slow or not running at all - there is NO guarantee the motor is dead or dying.
It can be a small thing called run-capacitor, which helps these types of motors to run at their best.
This guide is for AEG/Electrolux DD8760
Needless to say - I don't encourage you to do this repair yourself.
If you anyway decide to go on, you are doing this at your own risk.
Pay attention because you will mess with 240 V AC - Lethal if you don't pay attention.
Remove the three lower blinds to expose the filter. Then remove the filter.
Once the filter is removed, you can see the controller box over to the right.
You will need the PNC number to be able to order the correct parts. The PNC number is listed on a sticker behind the lower blind.
Identify the controller box as the black box on the image.
With a short barrel screewdriver and torx 10 bit, remove the two screws at the arrows.
The lid is "hinged" in the back with two tabs. Make sure you see how they works. Spend the time here, to save it when putting it together again.
At the arrow you see the so-called run-capacitor. This is the one you want to replace.
It is connected to the motor via two leads with connectors. They comes off easy.
Re-connect the device to mains, and try device, just to make sure the motor now spins much faster - Still keep clear from the open device
Secure the screws again
Insert the filter (Maybe after you have given it a good cleaning)
Put the blinds back on
Reconnect the device to the mains power and you are done.
If replacement of the run-capacitor does not improve the motor behavior you may want to replace the motor.
One Comment
Just changed the run capacitor on my cooker hood as fan only running slow and hums if your change speed, but no increase in fan speed, so this would surgest the motor is at fault??
