Introduction
If you have damage to the front plate,screen or need access to the screws behind the plate, this guide will tell you how to do so.
Tools
Parts
No parts specified.
With the small plastic opening tool, undo the plastic clips around the back lid.
Remove the six 4 mm screws in order to access the front plate. Use a Phillips #00 screwdriver.
Use a plastic opening tool to pry the top three sides of the bezel. Since there is glue under the bezel, gently pivot the face at the bottom off the Kindle and slide the clips out.
4 other people completed this guide.
Wear work gloves as the tool can easily slip and stab you in the hand.
BRUCE - Reply
