Kindle Touch Battery Replacement
  1. Kindle Touch Battery Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Battery Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Battery Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch Battery Replacement: step 2, image 1 of 2 Kindle Touch Battery Replacement: step 2, image 2 of 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch Battery Replacement, Battery: step 3, image 1 of 3 Kindle Touch Battery Replacement, Battery: step 3, image 2 of 3 Kindle Touch Battery Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove these 5 screws.
  4. Kindle Touch Battery Replacement: step 4, image 1 of 3 Kindle Touch Battery Replacement: step 4, image 2 of 3 Kindle Touch Battery Replacement: step 4, image 3 of 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
Adam Yerly
1,933 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
8 Guides authored
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 126
All Time: 10,115
