Introduction
I had a Kindle Fire with a swollen battery, and instead of just e-wasting the whole unit, I decided to fix it. Follow along for the ride.
If you decide to undertake a similar project: understand that the battery could explode and possibly the screen could shatter sending shards of glass towards your being. If you're unsure about this, or you prefer to stay safe, don't try this repair for a bulging battery.
  1. Start by removing the plastic cover to the speakers and webcam. I used a couple of spudgers, but you can also see the exploded version from the product video still I included, as well. Take your time, this is probably the most patient part of the whole repair. Start by removing the plastic cover to the speakers and webcam. I used a couple of spudgers, but you can also see the exploded version from the product video still I included, as well. Take your time, this is probably the most patient part of the whole repair. Start by removing the plastic cover to the speakers and webcam. I used a couple of spudgers, but you can also see the exploded version from the product video still I included, as well. Take your time, this is probably the most patient part of the whole repair.
    • Start by removing the plastic cover to the speakers and webcam. I used a couple of spudgers, but you can also see the exploded version from the product video still I included, as well. Take your time, this is probably the most patient part of the whole repair.
  2. I'm not positive, but I think these were T5 screw sizes. Keep them in order.
    • I'm not positive, but I think these were T5 screw sizes. Keep them in order.
  3. You can see the two ribbon cables the keep the display and controls connected on the bottom of the frame. I've already peeled back the battery connector for this shot, sorry for not giving you an in-progress shot, but it's pretty obvious. You can see how much my screen was bulging in the second photo. This is the dangerous part
    • You can see the two ribbon cables the keep the display and controls connected on the bottom of the frame. I've already peeled back the battery connector for this shot, sorry for not giving you an in-progress shot, but it's pretty obvious.
    • You can see how much my screen was bulging in the second photo. This is the dangerous part
  4. The connector is hidden under some tape, shown peeled back here. After the risk of the screen shattering, I'd say this is the most dangerous part for this repair. You're peeling off sealed batteries and physically manipulating them. Use Caution
    • The connector is hidden under some tape, shown peeled back here. After the risk of the screen shattering, I'd say this is the most dangerous part for this repair. You're peeling off sealed batteries and physically manipulating them. Use Caution
    • Use the spudger to lift the battery connector out of it's port. The less torque you use, the better (so don't go twisting and prying)
  5. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  6. Remove the two ribbon cables Both cable connections are covered in Capton tape, peel it off carefully, since we're just gonna re-use it upon reassembly. Both cable connections are covered in Capton tape, peel it off carefully, since we're just gonna re-use it upon reassembly.
    • Remove the two ribbon cables
    • Both cable connections are covered in Capton tape, peel it off carefully, since we're just gonna re-use it upon reassembly.
  7. These are both ZIF connectors, meaning they use a friction flap to hold them in place. Carefully lift the flap, and disconnect the ribbon cabling for both cables. These are both ZIF connectors, meaning they use a friction flap to hold them in place. Carefully lift the flap, and disconnect the ribbon cabling for both cables.
    • These are both ZIF connectors, meaning they use a friction flap to hold them in place. Carefully lift the flap, and disconnect the ribbon cabling for both cables.
  8. I wish I had better words here, but this battery is glued in there solid . Be careful it can explode or catch fire. Use common sense and good precaution.
    • I wish I had better words here, but this battery is glued in there solid .
    • Be careful it can explode or catch fire. Use common sense and good precaution.
    • The second photo here shows the battery after I spent probably 4 minutes slowly prying it away from the glue.
  9. I ordered my OEM replacement on eBay for about $34. I'm re-placing the tape mentioned earlier in this guide, in this shot.
    • I ordered my OEM replacement on eBay for about $34. I'm re-placing the tape mentioned earlier in this guide, in this shot.
  10. Reconnect the two ribbon connections, previously removed. Bottom edge slides in first (no, this isn't a shot of my smoke detector, you can see the bottom teeth of the screen along the edge)
    • Reconnect the two ribbon connections, previously removed.
    • Bottom edge slides in first (no, this isn't a shot of my smoke detector, you can see the bottom teeth of the screen along the edge)
    • When I re-assembled, I got a black screen, which turned out to be an improperly seated right ribbon connection. Take your time and check your connections.
  11. Once you have both ribbon cables re-seated and the Capton tape re-installed, reconnect the battery.
    • Once you have both ribbon cables re-seated and the Capton tape re-installed, reconnect the battery.
    • I like to check that connections are working before sealing everything back up (re-install the screws, re-attach the plastic screw cover, to finish).
Steve C
151 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 146
All Time: 3,084
