Image 1/2: The cover is secured by two tabs at either end and adhesive tape in the center. Image 2/2: Gently pry at the tabs and insert a spudger between the cover and the kindle body.
  • Remove the speaker cover.
    • The cover is secured by two tabs at either end and adhesive tape in the center.
  • Gently pry at the tabs and insert a spudger between the cover and the kindle body.
Image 1/1: Make sure not to lose the screws because they will be necessary when securing the the speakers in the reassembly process.
  • Remove the six T3 torx screws.
  • Make sure not to lose the screws because they will be necessary when securing the the speakers in the reassembly process.
Image 1/2: Image 2/2:
  • Detach the cover clips from the kindle frame.
Image 1/1: Try not to damage the connections.
  • Disconnect the cable that holds the two halves of the kindle together.
    • Try not to damage the connections.
Image 1/1: These connections are very important. Do your best to not damage them.
  • Using the spudger, remove the power button and micro-USB port cables.
    • These connections are very important. Do your best to not damage them.
Image 1/1: Once the speakers are removed, put the new ones in their place and put the kindle back in reverse order.
  • Remove the Dolby speakers which are located in the corners of the device.
  • Once the speakers are removed, put the new ones in their place and put the kindle back in reverse order.
Tyler Gosson
368 Reputation
2 Guides authored
UMass Dartmouth, Team 1-2, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-2, Duarte Fall 2014
UMASSD-DUARTE-F14S1G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 865
