Introduction
The Headphone Jack itself is easy to change. However getting there can be a problem to some, follow these steps and replacement should be a breeze. This guide will demonstrate how to remove the following:
1.Speaker Cover
2. Back Cover
3. Headphone Jack connector
In order to complete this guide you will need the proper tools, a new headphone jack, and about 30 minutes to complete the replacement.
Image 1/3: Begin your replacement by inserting a plastic opening tool at the corner of the speaker cover Image 2/3: Gently pry the cover apart from the device, using the plastic opener. Image 3/3: The device is held on by adhesive and two plastic tabs on the corners
  • The speaker cover is the shinny black plastic piece on the back of the device.
    • Begin your replacement by inserting a plastic opening tool at the corner of the speaker cover
    • Gently pry the cover apart from the device, using the plastic opener.
      • The device is held on by adhesive and two plastic tabs on the corners
Image 1/2: Make sure not to lose the screws because they will be necessary when securing the speakers in the reassembly process Image 2/2: Make sure not to lose the screws because they will be necessary when securing the speakers in the reassembly process
  • Using a T3 torx screw driver remove the 6 fuchsia colored screws located under the speaker cover
  • Make sure not to lose the screws because they will be necessary when securing the speakers in the reassembly process
Image 1/2: Pry apart the two pieces by sliding the opening tool along the edge Image 2/2: Detach the cable connecting the screen and the back cover.
  • Gently wedge a plastic opening tool between the screen and back cover.
    • Pry apart the two pieces by sliding the opening tool along the edge
  • Detach the cable connecting the screen and the back cover.
Image 1/3: To remove the headphone jack Image 2/3: Remove the silver T3 torx screw that is attaching headphone jack to the device Image 3/3: Using the spudger remove the electrical connector
  • The headphone jack is located in the back cover on the top right corner.
  • To remove the headphone jack
    • Remove the silver T3 torx screw that is attaching headphone jack to the device
    • Using the spudger remove the electrical connector
  • To attach the new headphone jack
    • Align the holes on the electrical connector to the two black pegs on the device. Push down to adhere.
    • Adjust the headphone jack to the proper position so that the screw holes line up.
    • Using the silver T3 screw, Attach the headphone jack to the device using a T3 torx screwdriver
Andrew Connors
146 Reputation
1 Guide authored
UMass Dartmouth, Team 1-2, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-2, Duarte Fall 2014
UMASSD-DUARTE-F14S1G2
4 Members
5 Guides authored
One Comment
The screw that connects the headphone jack is larger than the the T3 fuschia screws. The screwdriver I ordered was too small.
kclong1 - Reply
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 140
All Time: 3,524
