Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide explains how to remove the screen from the Kindle Fire HD 6. This guide has many steps, so make sure to give yourself enough time to complete all of these.
Note that some of the connectors in this guide are delicate and require special removal, so make sure to read the steps completely before attempting them.
  1. Place the device face down on a clean cloth or another smooth surface.
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Carefully separate the back panel from the rest of the device internals. Carefully separate the back panel from the rest of the device internals.
    • Carefully separate the back panel from the rest of the device internals.
  3. Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
    • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
  4. Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector.  Gently pull it straight up. Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector.  Gently pull it straight up.
    • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
  5. Lift the speaker out of the device. Lift the speaker out of the device.
    • Lift the speaker out of the device.
  6. Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
    • Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
  7. Be careful not to damage the camera lens as you remove the camera. Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base. Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
    • Be careful not to damage the camera lens as you remove the camera.
    • Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
    • Gently pry the battery free from the adhesive holding it in place.
    • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
    • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
    • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
  8. Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up. Remove the battery.
    • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
    • Remove the battery.
  9. Zero insertion force connectors can break easily. Before performing this step, read the iFixit Guide to Recognizing and Disconnecting Cable Connectors to find out how to safely remove them. Use the tip of the spudger to disconnect the two zero insertion force connectors on the bottom and top of the motherboard.
    • Zero insertion force connectors can break easily. Before performing this step, read the iFixit Guide to Recognizing and Disconnecting Cable Connectors to find out how to safely remove them.
    • Use the tip of the spudger to disconnect the two zero insertion force connectors on the bottom and top of the motherboard.
    • The first connector is attached to an orange tape, and is located in the bottom-right corner of the motherboard. Remove this connector.
    • The second connector is long and thin, and is located at the top of the motherboard, a bit to the right of center. Remove this connector.
  10. Disconnect the black and white connector at the very top-center of the motherboard by unclipping it using the flat side of the spudger. Disconnect the black and white connector at the very top-center of the motherboard by unclipping it using the flat side of the spudger.
    • Disconnect the black and white connector at the very top-center of the motherboard by unclipping it using the flat side of the spudger.
  11. Unscrew the ten 3.5mm T5 Torx screws around the edge of the motherboard.
    • Unscrew the ten 3.5mm T5 Torx screws around the edge of the motherboard.
  12. Starting from the bottom, lift the motherboard out of the device. You will have to push the motherboard about two millimeters toward the top of the device to unhook the top edge. Starting from the bottom, lift the motherboard out of the device. You will have to push the motherboard about two millimeters toward the top of the device to unhook the top edge.
    • Starting from the bottom, lift the motherboard out of the device. You will have to push the motherboard about two millimeters toward the top of the device to unhook the top edge.
  13. Remove the five gold-colored 2mm T5 Torx screws from the metal plate.
    • Remove the five gold-colored 2mm T5 Torx screws from the metal plate.
  14. An orange tape that connects to the motherboard runs through the metal plate. When removing the plate, be careful to maneuver the plate around the tape, and make sure not to stretch or rip the tape. Lift the metal plate up using the flat side of the spudger.
    • An orange tape that connects to the motherboard runs through the metal plate. When removing the plate, be careful to maneuver the plate around the tape, and make sure not to stretch or rip the tape.
    • Lift the metal plate up using the flat side of the spudger.
  15. Remove the metal plate from the device. Remove the metal plate from the device.
    • Remove the metal plate from the device.
  16. Unscrew the four silver-colored 2mm T5 Torx screws that connect the screen to the bezel.
    • Unscrew the four silver-colored 2mm T5 Torx screws that connect the screen to the bezel.
  17. Be careful not to scratch the screen while you're removing it. After you've removed the screen, place it on a cloth or another smooth surface to make sure that you don’t scratch it once it is out of the device. Push the suction cup against the screen. Press down firmly on the center of the suction cup to create a good seal. Gently pull the screen out of the device.
    • Be careful not to scratch the screen while you're removing it. After you've removed the screen, place it on a cloth or another smooth surface to make sure that you don’t scratch it once it is out of the device.
    • Push the suction cup against the screen. Press down firmly on the center of the suction cup to create a good seal.
    • Gently pull the screen out of the device.
  18. Place your screen on a cloth or another smooth surface to prevent it from getting scratched.
    • Place your screen on a cloth or another smooth surface to prevent it from getting scratched.
Cassandra Beck
852 Reputation
5 Guides authored
Cal Poly, Team 70-4, Forte Winter 2015 Member of Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 35
All Time: 10,050
