Keurig K10 Mini Plus Cup Holder Replacement
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: step 1, image 1 of 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: step 1, image 2 of 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: step 1, image 3 of 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: step 2, image 1 of 2 Keurig K10 Mini Plus Cup Holder Replacement: step 2, image 2 of 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Mark Henein
369 Reputation
2 Guides authored
USF Tampa, Team 17-6, Blackwell Winter 2016 Member of USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
2 Members
2 Guides authored
One Comment
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,428
