Introduction
Go to step 1 ↓This guide will show you how to replace the water pump in a Keurig K-Duo. Replacing the water pump may be necessary in the event that there is no water coming out.
The water pump is a crucial component that moves water through the system for brewing coffee. Over time, these pumps can fail for several reasons, ranging from wear and tear to improper maintenance or environmental factors.
Tools
Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
Gently disconnect the 2-pin terminal block that has the label "Water Pump" on the motherboard.
Gently disconnect the 4-pin terminal block that has the label "IR Sensor."
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
