Shop the Holiday Gift Guide
Keurig K-Duo Rear Plastic Panels Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
119
All Time:
1,212
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
In this guide, we’ll walk you through the process of replacing the back panels of a Keurig K-Duo in the case that the plastic panel has been broken, faded out, or you simply just want to access other components.
Tools
    1. Keurig K-Duo Rear Plastic Panels Replacement, Rear Plastic Panels: step 1, image 1 of 1
      • Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
      Ask FixBot
    2. Keurig K-Duo Rear Plastic Panels Replacement: step 2, image 1 of 3 Keurig K-Duo Rear Plastic Panels Replacement: step 2, image 2 of 3 Keurig K-Duo Rear Plastic Panels Replacement: step 2, image 3 of 3
      • Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
      Ask FixBot
    3. Keurig K-Duo Rear Plastic Panels Replacement: step 3, image 1 of 3 Keurig K-Duo Rear Plastic Panels Replacement: step 3, image 2 of 3 Keurig K-Duo Rear Plastic Panels Replacement: step 3, image 3 of 3
      • To remove the back panels, grip each side firmly.
      • Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
      Ask FixBot
Adrian Guzman
610 Reputation
4 Guides authored
Cuesta, Team 10-3, Krynen Fall 2024 Member of Cuesta, Team 10-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 119
All Time: 1,212
