Shop the Holiday Gift Guide
Keurig K-Duo Pod Holder Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
48
Past 30 Days:
161
All Time:
1,702
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
The pod holder in the Keurig K-Duo is necessary to brew pod-style coffee. It can quickly become unusable if the needle inside is bent or the gasket is broken off. Replacing the pod holder is both inexpensive and simple to do.
Before you begin, ensure the machine is powered off and has cooled down if it was used recently.
    1. Keurig K-Duo Pod Holder Replacement, Pod Holder: step 1, image 1 of 3 Keurig K-Duo Pod Holder Replacement, Pod Holder: step 1, image 2 of 3 Keurig K-Duo Pod Holder Replacement, Pod Holder: step 1, image 3 of 3
      • Pull the silver handle upwards to open the compartment that holds the pod holder.
      Ask FixBot
    2. Keurig K-Duo Pod Holder Replacement: step 2, image 1 of 3 Keurig K-Duo Pod Holder Replacement: step 2, image 2 of 3 Keurig K-Duo Pod Holder Replacement: step 2, image 3 of 3
      • Pinch the tabs while pulling the pod holder upwards and out of the machine.
      • Be wary of the needle above the pod holder!
      • If the pod holder is stuck, try pushing it back into the machine and pulling it out again.
      Ask FixBot
    3. Keurig K-Duo Pod Holder Replacement: step 3, image 1 of 1
      • Align the replacement pod holder with the three slots in the machine
      • Make sure the tabs are aligned to prevent damaging the machine and/or the pod holder.
      Ask FixBot
    4. Keurig K-Duo Pod Holder Replacement: step 4, image 1 of 1
      • Push the pod holder down until it snaps securely into place.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
AbelNegassi
140 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 48
Past 30 Days: 161
All Time: 1,702
