Shop the Holiday Gift Guide
Keurig K-Duo Motherboard Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
140
All Time:
2,261
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
In this guide, we’ll walk you through the process of replacing the Motherboard for a Keurig K-Duo in the case that there are electrical issues. These issues most commonly arise from overheating, built-up debris, water damage, or physical damage.
The motherboard serves as the main control board that manages the machine’s electrical and operational functions. The motherboard is critical for ensuring that all parts, such as the water pump, heating element, and valves, work together in the correct sequence for brewing coffee.
In order to replace the motherboard, skills for soldering are involved in this process.
Tools
    1. Keurig K-Duo Motherboard Replacement, Rear Plastic Panels: step 1, image 1 of 1
      • Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
      Ask FixBot
    2. Keurig K-Duo Motherboard Replacement: step 2, image 1 of 3 Keurig K-Duo Motherboard Replacement: step 2, image 2 of 3 Keurig K-Duo Motherboard Replacement: step 2, image 3 of 3
      • Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
      Ask FixBot
    3. Keurig K-Duo Motherboard Replacement: step 3, image 1 of 3 Keurig K-Duo Motherboard Replacement: step 3, image 2 of 3 Keurig K-Duo Motherboard Replacement: step 3, image 3 of 3
      • To remove the back panels, grip each side firmly.
      • Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
      Ask FixBot
    1. Keurig K-Duo Motherboard Replacement, Motherboard: step 4, image 1 of 2 Keurig K-Duo Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Gently disconnect all eleven connectors from the motherboard.
      • Gently pull off the four remaining wire terminals.
      • It may be helpful to label each terminal for its original corresponding connection.
      • Be careful not to damage green wire. It will have to be removed by soldering.
      Ask FixBot
    2. Keurig K-Duo Motherboard Replacement: step 5, image 1 of 2 Keurig K-Duo Motherboard Replacement: step 5, image 2 of 2
      • Pull out and flip the motherboard so the back is now facing you.
      • Desolder the solder pad connected to the green wire.
      • Re-solder the existing green wire to the new motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Adrian Guzman
610 Reputation
4 Guides authored
Cuesta, Team 10-3, Krynen Fall 2024 Member of Cuesta, Team 10-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G3
4 Members
60 Guides authored
2 Guide Comments
What are the 4 leads that protrude from the motherboard to a recess(covered) on the bottom of the Kuerig? Are these test points for the motherboard? If so, how do I test the board and what values should I look for?
Rich - Reply Share
How about post detailed instruction how to remove this board from the K-Duo 5100 machine. Not worry about the wires, I just can't see how to pry this board loose. Thanks.
Bronek - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 140
All Time: 2,261
