Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓Use this guide to diagnose and replace a faulty turbo boil burner element in a Kenmore or Frigidaire-family smooth-top stove. This style of radiant element uses a primary winding for normal heat and a secondary winding for the turbo-boil function. If one winding fails, the burner may stay cold, heat only part of the element, or stop switching to the high-heat range. This guide was written around the large left-front burner, so wire colors, bracket positions, and screw locations may vary on other models.
Step 1 Identify the turbo boil burner windings
Identify the large turbo boil burner that is not heating correctly.
Step 2 Understand the turbo boil switch
Set the burner control below 5 to power only the primary winding.
At 5 or higher, the secondary switch closes and powers the full burner.
Step 5 Access the burner switch
Pull the knob straight off the faulty burner switch.
Use a screwdriver to remove the two screws behind the knob.
Slide the burner switch out from the back of the control panel.
Step 6 Document the switch wiring
Inspect the back of the switch and identify the two incoming 240 volt wires.
Identify the two orange wires that run from the switch to the primary winding.
Identify the white secondary wire and the blue wire leaving the small secondary switch.
Step 7 Access the burner wiring for testing
Remove the rear panel to access the burner wiring.
Set a multimeter to measure resistance in ohms.
Step 8 Test the primary winding
Connect the multimeter leads to the two orange primary-winding wires.
Look for a stable resistance reading.
Step 9 Test the secondary winding
Connect one multimeter lead to the white secondary burner wire.
Connect the other lead to the blue wire leaving the small secondary switch.
Step 10 Interpret the test results
Replace the burner element if either winding reads open or far outside the expected range.
If both windings test good but the burner still doesn't heat, diagnose or replace the burner switch.
Step 11 Remove the front cooktop screws
Find the two screws under the front ledge of the cooktop, closest to the oven cavity.
Use a screwdriver to remove only those two cooktop screws.
Step 13 Support the burner brace
Support the faulty burner brace with a helper or a sturdy box placed under the center.
Use a stubby screwdriver to reach the brace screws.
Remove the screw from each end of the brace while it is supported.
Step 14 Document the burner position
Note which mounting holes the old burner uses on both sides before lifting it from the brace.
Step 15 Remove the old burner element
Disconnect all wires from the burner element.
Squeeze the tab on one lower mounting clip while lifting the burner so the clip clears the slot.
Repeat on the other side.
Lift the burner out of the brace.
Step 16 Transfer the mounting clips
Move the two lower mounting clips to the same numbered holes on the new burner.
Use the recorded hole positions from the old burner to place one clip on each side.
Step 17 Install the new burner element
Set the new burner onto the brace using the same slots as the old burner.
Snap the lower mounting clips into the brace slots.
Reconnect all six wires to the same terminals shown in your photos or wiring diagram.
Step 18 Reassemble the cooktop
Raise the brace back against the underside of the glass cooktop.
Use the helper or sturdy box to support the brace while you reinstall the screw at each end.
Lower the cooktop and reinstall the two front ledge screws.
Reinstall the rear panel, the burner switch, the two switch screws, and the knob if you removed them.
Step 19 Test the burner
Plug the stove back into the wall outlet.
Turn the repaired burner to high and watch the element heat.
The full burner should heat across both the primary and secondary sections.
If the burner still doesn't heat after replacement, unplug the stove and recheck the wiring photo or diagram against the actual connections. Repair didn't go as planned? Ask our Answers community for help.
