Introduction
Use this guide to replace a faulty water level sensor.
Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
Lifting from the rear, remove the top panel.
Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
From the bottom, pull out and remove the component cover.
Remove wires from water level sensor.
With a Phillips screwdriver remove the mounting screw.
Cut the zip tie and remove water level hose.
