Kemove 98 SE Keyboard Keycap and Switch Replacement
  1. Kemove 98 SE Keyboard Keycap and Switch Replacement, Keyboard Keycap and Switch: step 1, image 1 of 1
    • Unplug your keyboard from power outlet and/or your computer.
    • Line up your key cap puller to the key you want to replace and press down lightly till it doesn't move.
  2. Kemove 98 SE Keyboard Keycap and Switch Replacement: step 2, image 1 of 2 Kemove 98 SE Keyboard Keycap and Switch Replacement: step 2, image 2 of 2
    • Gently pull the key from the board.
    • Use a small brush to clean the area.
  3. Kemove 98 SE Keyboard Keycap and Switch Replacement: step 3, image 1 of 2 Kemove 98 SE Keyboard Keycap and Switch Replacement: step 3, image 2 of 2
    • Align the switch puller vertically around the switch.
    • Squeeze the switch puller gently and pull the switch out.
  4. Kemove 98 SE Keyboard Keycap and Switch Replacement: step 4, image 1 of 1
    • Align the new switch so its plugs match the corresponding plugs on the board.
    • Gently push it down.
  5. Kemove 98 SE Keyboard Keycap and Switch Replacement: step 5, image 1 of 3 Kemove 98 SE Keyboard Keycap and Switch Replacement: step 5, image 2 of 3 Kemove 98 SE Keyboard Keycap and Switch Replacement: step 5, image 3 of 3
    • Line up the new keycap with the switch.
    • Press it down gently till it reaches the bottom.
    • If it doesn't go down, then rotate the key cap till it goes down fully. It should match the other key's height.
  6. Kemove 98 SE Keyboard Keycap and Switch Replacement: step 6, image 1 of 1
    • Repeat the steps 2-5 for any other keys you want to replace.
    • Spray the microfiber cloth a few times with isopropyl alcohol. If you use a bottle of isopropyl alcohol, put 7-8 drops on the microfiber cloth and gently clean the area
    • Gently wipe your keyboard with the cloth to clean the keyboard.
    • After drying for 5-10 minutes, you can connect your keyboard to computer/power and use it.
    • Use the Kemove app to change the backlight color on your new keycap.
Once you've installed all the new keycaps into place, you should inspect to make sure each key is level and not contacting its neighbors. Reconnect the keyboard, and test each key to ensure your new keycaps fit and feel as nice as you hope. With your new keycaps installed, your Kemove K98 SE is ready to be used as however you want.
Asliddin Madumarov
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 160
