Introduction
These switched-outlet powerstrips are expensive. Over time the rocker switches can become frozen, usually due to not being used for a while. Also, the better powerstrips have spring-loaded covers over the plug insert holes which can also seize up. I decided to see if I could fix it rather than replace it.
This is a powerstrip used in Australia but the principle should be the same everywhere
After removing the backplate, remove the four screws that secures the internal assembly to the box.
The disassembled powerstrip. The rocker switches are in the section removed from the box. In the box, there are spring-loaded covers where the appliance power plugs are inserted. These covers prevent dirt entering the box.
Spray a very small amount of WD40 into the rocker mechanism of each switch. Then manipulate the switches until they move freely.
Each cover plate has a small spring, these can be rusty which will prevent the covers moving, thereby preventing the insertion of an appliance plug.
Spray a small amount of WD40 onto the springs, then manipulate the covers until they move freely.
