Jura Z7 brewing unit replacement
  1. Jura Z7 brewing unit replacement, Brewing unit: step 1, image 1 of 2 Jura Z7 brewing unit replacement, Brewing unit: step 1, image 2 of 2
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • Position the machine with the water tank side facing you.
    • The panel covering the brew group is fixed at the top edge with two oval head screws.
    • These screws have an oval head and look like rivets. They require a special tool or bit for unscrewing. Here is a DIY guide . In a pinch you can also use needle nosed pliers. Jura wants to keep us out of our own machines!
    • Remove the two oval head screws and lift the panel out.
    • There it is: the brewing unit.
  2. Jura Z7 brewing unit replacement: step 2, image 1 of 1
    • The photo is from a Jura J5, but the brewing unit is basically the same and you can easily see how the brewing unit is attached:
    • Two Torx T20 screws with fine thread
    • One Torx T15 screw
    • The hot water inlet is plugged in.
    • The hose with the coffee spout is plugged on top.
  3. Jura Z7 brewing unit replacement: step 3, image 1 of 3 Jura Z7 brewing unit replacement: step 3, image 2 of 3 Jura Z7 brewing unit replacement: step 3, image 3 of 3
    • Unscrew the two Torx T15 machine screws.
    • Unscrew the Torx T15 screw at the bottom of the hot water inlet.
    • Pull the brewing unit out to you. The hose to the coffee spout is still attached at the top.
    • Pull off the hose to the coffee spout.
  4. Jura Z7 brewing unit replacement: step 4, image 1 of 3 Jura Z7 brewing unit replacement: step 4, image 2 of 3 Jura Z7 brewing unit replacement: step 4, image 3 of 3
    • Start now with the replacement or revision of the brewing unit.
    • If you want to disassemble the brewing unit for cleaning and installing new seals, follow this or this guides.
    • There is one small difference with this brewing group: the drainage valve is fitted with a cover, but this is easy to remove. Unscrew the two Torx T8 screws.
    • Use these instructions to overhaul the drainage valve.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
202,382 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,103 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 41
All Time: 1,780
