Introduction
The brew assembly in ENA models is basically structured in a similar way to the other Jura brewing groups. Special features are pointed out in the instructions. The brew group is the same in models A1 - A9 and micro 1 - micro 90.
Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
Remove all coffee beans.
Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
Unscrew the two T15 Torx screws that secure the side panels at the top.
The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
Lay the machine on its side.
Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
In the same way, insert another opening pick on the opposite edge.
Peel off the silicone tube with a pair of tweezers.
Unscrew the Torx T20 machine screw in the middle on the left.
Unscrew the Torx T20 machine screw in the middle on the right.
Unscrew the Torx T15 screw at the bottom right.
The brew assembly is now free. Gently tip it out at the bottom and remove it from the device.
The drive is on the left, the pulp shovel can be seen on the right.
Remove the two Torx T15 screws that hold the drive in place.
Remove the two Torx T20 machine screws that secure the drive to the upper piston.
Lift away the top cover with the coffee dispensing hose
Pull the metal retaining plate out of the upper piston. Note the orientation for later assembly. The top cover has a pin that must fit into the corresponding hole on the plate.
Turn the drive until it detaches itself from the brew assembly upwards
The axis of the lower piston is secured with two ring cotter pins on the left and right. Use a sharp tool and pry out the two cotter pins.
Push out the axle.
Now you can turn the mechanics a little to the side and push out the piston. Further dismantling is possible, but not necessary. Make sure that there are two more metal rings at the top under the fork, these should stay in and not get lost.
6 other people completed this guide.
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
3 Comments
I have pulled everything Out and cleaned it, reinstalled it and now when the plunger is at the top it just keeps grinding on the back gear. What did i do wrong?? Please help im going nuts!!
I have the same problem
Nic -
@nic14126 go to the Answer forum on here. There you can ask your question. In your question, give us the the make and model number for your Jura and give us all the history about what is going on with it. You cannot get an answer to your problem on this part of iFixit.
@nic14126 ga naar het antwoordforum hier. Daar kun je je vraag stellen. Vermeld in uw vraag het merk en modelnummer van uw Jura en geef ons alle informatie over wat er aan de hand is. Op dit deel van iFixit krijgt u geen antwoord op uw probleem.
