Introduction
Many of Jura's Devices have a Valve made of Ceramic, which is to call Multi-way valve. It controls the flow of Hot Water, Steam and - of course - Coffee. If this Valve breaks, the machine is bricked, often with an Error 6. There are multiple ways, this can be caused:
- (Micro-)crack in the distributor head
- Calcification, especially of the Ceramic disks/seals
- Defective microswitches
- Driver ground down
- Defective Motor
A repair doesn't always work, but because the replacement is not cheap, it's worth a try. The replacement of the microswitches is relatively easy.
The repair is shown on an Z6 (2018). The valves are very similar on other Models.
Unscrew the two Story T20 Screws from the Flange of the Motor and take it out carefully.
The Image shows an old and new switch. They are the most common cause of error of the Valve. It is clearly visible how the shutter button has been ground down by about 1 mm and can't activate.
One of the microswitches is plugged into the distributor head and one into the motor flange. It is held in place by side catches. Push them to the side and lift out the switches.
Desolder the Switches and resolder the new ones.
Good replacements are:Cherry DB3, Cherry DB3 or SAIA XCG3Z1.
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
100%
Friesenjunge226 is helping us fix the world! Want to contribute?
Start translating ›
