Introduction
The side buttons on the Jawbone MINI JAMBOX control its power and bluetooth pairing. With excessive use or use in dirty conditions, the buttons can begin to stick. This issue should be resolved by thoroughly cleaning the button.
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
To reassemble your device, follow steps 1 through 5 in reverse order.
