Introduction
The MicroUSB port can be found on the I/O board. We will focus on removing the I/O board first and then welding a new MicroUSB on.
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
Gently slide the NFC chip into the device through the slot that the wire comes from.
what if the wire DID disconnect? could s.o. add a detail pic of exactly where the cables connect on the chip?
Need the real name of the NFC chip, caus i broked and need to change
Thanks
Need the real name of the NFC chip, cause i broked and need to change
Thanks
My chip reads
WN-3088 20130912
Remove the two 7.0 mm Phillips #1 screws.
Carefully detach the silver plastic cover by pulling both ends off.
Separate the silver plastic piece by pulling it off from the middle.
Tutto molto interessante.
Ma la cosa più importante è:
Dove acquistare gli altoparlanti ??
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Keeping the tape intact is impossible - I replaced it with electrical tape.
Use the black spudger to disconnect the auxiliary wire from its socket.
What is the function of auxi. Wire
When you plug in the audio jack it goes to the motherboard, the amplifier and then to the wire directly to the speakers.
Carefully remove the cable connecting the control chip to the motherboard.
What's the name of the cable connecting the control chip to the motherboard
I want motherboard control chip
connecting the control chip kitne ka hai
Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
Remove the 7.0 mm Philips #1 screw that connects the I/O board to the casing.
Pry off the loose MicroUSB port.
Use the soldering iron to solder the new MicroUSB port onto the I/O board.
Don't pry anything off! Desolder the bad port!
If you pry, you most likely will lift the copper traces and ruin the very traces you will need to solder to.
what do you do with the 5 charge pins? glue them in?
Where do you get the new micro USB port?
14 other people completed this guide.
18 Comments
In my model MicroUSB is on separate board and both ports were covered by min. 20ml of hot-melt adhesive.
I spent hour on cables separation by sponge pieces - it is very important to use again hot glue to restore hermetic (!) speakers encloser, otherwise you get annoing sound of shaking cable.
Mine was like that too! %#*@ hot glue made it a pain to pull the usb out. sadly i need a new usb board... mine 2 pads were completely gone... not worth trying to even fix the contacts...
Good clear guide, but as reported by other earlier, steps starting from 17 will be different in case I/O board with USB is a separate piece of board covered with glue. You need hot glue gun to reassemble the unit after replacing the USC socket. Guy in below link shows the struggle with the glue: https://www.youtube.com/watch?v=N6ahpRyK...
Anywhere I can just buy the whole usb i/o board?
Hi
Did you find it and where ?
Thank You
Hi,
Link not valid anymore :o(
Any other ?
Thank You
Where can I get he micro usb board????
Hi,
Thank You
Hi,
Did you find it and where?
Thank You
I’m searching too where I can find micro usb board.
Hi ,
Thank You
In my case, the usb slot is totally “glud” from behind:(
Hello i have repaired my jbl wih usb ports from Aliexpress . Thanks !!!!
Bloody h*ll, that was murder. Not the guide, but the task. It took me from 10am through to 2.30pm. My Flip 2 was a different build, and JBL had hot-glued everything under the motherboard. What a PIA. I should’ve just dumped the thing, but I persisted and to my surprise the repair worked. The Cage on my variant had an extra screw under the LED board, so be aware folks. Difficulty? 8/10 in my books. Buy a new one & flog your old (working) parts to mugs on eBay like me who have egos too big for their boots. I’d give the guide about a 7 as so much of my build was different (including screw sizes and board configurations), so I could only partly use it. But thanks anyway.
I accidentally broke the power cable which is connected to motherboard and on off button.. please tell how to repair or where to find replacement of that flex cable
Need a store that do this for a living, I dont want to take any chance I might ruined
From where i can buy these speakers?
Nitin Z - Reply
First thing I did was rip the wire from the NFC chip! Luclily I don't need it as I only ever use my flip with my iPhone.
Ken McMahon - Reply
