Introduction
How to disassemble the JBL Charge 2 for a motherboard replacement.
Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
Remove the end cap of the device. Repeat the same process to remove the other end cap.
To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
Twist off the end cap and remove them from the device.
Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
Pry away the plastic battery cover with a plastic spudger.
Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
Slide the battery free.
Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
Pull out the speakers from the device.
Disconnect the wiring from the speaker by using the fine tip pry tool.
Remove the speakers from the device.
Use a spudger to disconnect the gold antenna connector from the main circuit board.
Next, disconnect the control-panel ribbon by prying out the grey plastic tab using a plastic opening tool. The ribbon should freely come out afterwards.
