Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Use this guide to trade your optical drive for a second hard drive.
  1. Power down your Mac mini, disconnect all of the cables, and flip it over. Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    A spackle knife makes these steps go much faster.
    jouniseppanen - Reply
  2. Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing. There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Once you have the first side free, rotate the Mac mini and start prying up on the front edge. Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time. You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Keep working around the perimeter, freeing the clips along the final edge. Keep working around the perimeter, freeing the clips along the final edge.
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Flip the Mac mini back over and lift the top housing off of the lower housing. Flip the Mac mini back over and lift the top housing off of the lower housing.
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand. First remove the AirPort antenna (the larger of the two), located near the power button. Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
    • First remove the AirPort antenna (the larger of the two), located near the power button.
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
  8. Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket. The ZIF cable lock will lift about 1 mm and stop. Do not try to completely remove the ZIF cable lock.
    • Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
    • The ZIF cable lock will lift about 1 mm and stop. Do not try to completely remove the ZIF cable lock.
    Now also lift the right side of the ZIF cable lock up from its socket.
    chriZ - Reply
    Good catch of the incomplete unlocking instructions. ;P
    lamarhavard -
    Hmmm... what if I didn't read this before and I removed the cable and the lock sort of broke?... what would happen... would I experience problems? I can still put the cable back in place and push the lock back down with the spudger.
    Dan O - Reply
    Same. I totally removed the lock , the edges are busted and won't stay in place, How can I get the cable to stay? what's the fix?
    Suzanne -
    Dan O & Suzanne, hold the cable in the socket and put a dab of hot glue on both sides, It's non-conductive and should hold...worked for me.
    lamarhavard -
    does any one know, where to get the connector from zhe ZIF Cable?
    someone, that preowned my mac broke the holder!
    julian gmeiner - Reply
    Julian, did you ever find where to get a replacement lock for the Zip Cable. Mine is also broken..
    Suzanne -
    This is not my first memory replacement in a Mini and I got over-confident and stupidly fully removed the audio cable ZIF lock and assumed I had broken something. But, now that I have read this guide more carefully, I am not sure. I sure would love to hear some detailed instructions for putting a ZIF lock back on.
    Is it possible that I have removed it without having broken it? If I have broken it, do I have to buy a new cable? Just a new ZIF lock? A new audio board? This is a 2.0 GHz A1176.
    Thanks!
    GalvanicMacPro - Reply
    Michael, Mine seems to be broken. I bought & tried the Kapton Tape that was suggested & still no sound.
    Suzanne -
    C’est la première que je doit déverrouiller un câble ZIF. Je précise qu’il faut lever à gauche et à droite, ça force un peu, prendre appui sur le boitier du Mac, comme e montre la photo.
    La partie noire reste dans la partie blanche (+1 mm), et la nappe flexible sort par le haut.
    Ludovic - Reply
  9. Lift the audio board ribbon cable up out of its socket.
    • Lift the audio board ribbon cable up out of its socket.
    • If it refuses to lift from its socket, the ZIF cable lock is not fully released. Make sure it is evenly lifted about 1 mm from the socket on the interconnect board.
  10. Rotate the mini so that the SuperDrive slot loading mechanism is facing you. Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
    • Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
    • Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
    • Use tweezers to grab the connector (as seen in the picture), not the wires.
    • The connector is located under the optical drive opening, next to the PRAM battery.
    Managed to leave this connected by flopping back the drive rather than totally removing
    pglock - Reply
    WATCH OUT!!
    separated one of the wires from the connector very easily. i would have preferred to use a spudger at this step. the tweezers in effect snipped the wire!!
    mklsvg - Reply
    As my experience you should definitely use angeled tweezers as shown in several pictures. To avoid stripped cable deflash sharp edges of the tweezers a little bit. I never experienced problems when using that kind of tool carefully.
    Timpetou - Reply
    I've had to remove a few of these connectors on iBooks and other small Apple devices ... I've found that, with careful and gentle pressure (working first one side and then the other) using a small flat-headed jeweller's screwdriver is best.
    Mike Haines - Reply
    I agree Mike.
    dixieskettlecorn -
    Note where the airport antennae connecting wire comes out from the interior along the top. When reassembling, it has to be routed the same way, or it won't reach its install position.
    robert - Reply
    If your fan runs at high speed after you complete this project, you have forgotten to reconnect the thermal sensor.
    Curt - Reply
  11. In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw. Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
    • In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
    • Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
  12. Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing. This screw is the longest of the four screws securing the internal frame to the bottom case.
    • Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
    • This screw is the longest of the four screws securing the internal frame to the bottom case.
  13. Remove the Phillips screw from the internal frame near the Bluetooth antenna. Remove the Phillips screw from the internal frame near the Bluetooth antenna.
    • Remove the Phillips screw from the internal frame near the Bluetooth antenna.
    Before removing any of these screws, there is another step needed which is not here:
    On the front of the optical drive, right side as you look at the slot-load, is a small blue board attached by a single black screw. This needs to be removed before the optical drive can be taken out.
    Mike Haines - Reply
  14. Remove the Phillips screw near the audio ports securing the internal frame to the bottom case. Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
    • Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
    On reassembly, if you don't have a magnetic screwdriver, a tiny dab of grease at the tip of your screwdriver will help hold the screw on the driver so you can lower it into the recessed slot.
    pfbloom - Reply
  15. Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught. It may be necessary to pull up near the interconnect board to separate it from the logic board.
    • Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
    • It may be necessary to pull up near the interconnect board to separate it from the logic board.
    At this point be careful that you don't pull out the Airport antenna ... but if you do, just check that it is back before re-assembling.
    Mike Haines - Reply
    During re-assembly, the internal frame has to go in at an angle ... the back of the optical drive goes in first.
    This means that you can seat the fan cover correctly, but more importantly, there is an interconnect board on the back of the optical drive that must be firmly pushed back into its housing on the logic board.
    Mike Haines - Reply
    Reassembly: Before slipping the main frame back into its place, refer to earlier photos, ensuring proper routing of the WiFi cable.
    Steve - Reply
    If, like me, you pull the wire on the airport antenna free, it snaps back into place easily. The connector is on the extra card screwed to the motherboard that looks like it has a phone battery embedded in it. The connector is at the top of the 'battery'. This accessory card is the wifi card, so it makes sense that the antenna plugs onto this.
    Dan - Reply
  16. The Bluetooth antenna is removed by simply lifting it up off the internal frame.
    • The Bluetooth antenna is removed by simply lifting it up off the internal frame.
    • Remove the Bluetooth antenna from the internal frame by pushing up on both sides of the board as close to the center post as possible.
    • This may require a bit of force.
    I tried using quite a bit of force and still this board would not come free. In the end I didn't remove it and found I could do the repair without removing it!
    Mike Haines - Reply
    use tweezers at other side to clamp and push the whitestud trough, otherwise you might brake it
    joost - Reply
    I left this piece in place and the optical drive wiggled around it. I applied as much force as I was comfortable with and I did not want to break the Blue Tooth antenna. This was a good work around and did not cause much if any trouble removing the old drive or placing the new drive into the computer.
    sikkingj - Reply
    Comme le dit Mike, l’antenne est un peu dure à enlever. Elle peut être laisée en place, à l’étape 20, lever le lecteur par le coin opposé à la carte d’interconnexion, pour extraire le lecteur par l’avant.
    Ludovic - Reply
  17. Remove the two Phillips screws securing the optical drive to the internal frame.
    • Remove the two Phillips screws securing the optical drive to the internal frame.
    A Phillips #0 is definitely required for this!
    Javier Campos Delgado - Reply
  18. Turn the mini 180 degrees and remove the two Phillips screws securing the optical drive to the internal frame on the other side.
    • Turn the mini 180 degrees and remove the two Phillips screws securing the optical drive to the internal frame on the other side.
  19. Remove the two Phillips screws securing the interconnect board to the optical drive.
    • Remove the two Phillips screws securing the interconnect board to the optical drive.
  20. Use the flat end of a spudger to separate the interconnect board from the optical drive.
    • Use the flat end of a spudger to separate the interconnect board from the optical drive.
  21. Lift the optical drive out of the internal frame.
    • Lift the optical drive out of the internal frame.
  22. Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure. Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    The bay and dvd drive cable at iFixit is $40.00 (Unibody Laptop Dual Drive)
    But for $10 more you can get an external casing that will protect your super drive form MCE (http://store.mcetech.com/Merchant2/merch...) A total of $50 dollars. It is what I used and works great and looks pretty and is guaranteed to protect your superdrive. MCE also gives you a disk with software to patch the DVD Player to work with external dvd drives. So For an extra $10 dollars you get better software functionality and a case for your super drive. It works great.
    Robert Wacker - Reply
    Robert, do you by chance also know where to buy an external drive case to make the old hard disk an external portable hard disk ?
    Nina Nokia -
    Early 2011 MacBook Pro was running slow with its 2TB hard drive running at 5400rpm. The DVD drive was almost never used. The iFixit part allowed me to place the hard drive in the DVD bay and place an SSD drive where the hard drive originally sat. Now the computer fires up almost instantly and runs so much cooler as the 2TB hard drive is only accessed as needed. A stunning transformation for a 7 year old laptop.
    Paul Cline - Reply
  23. Make sure that the hard drive connectors are facing down before placing it into the enclosure. Gently place the hard drive into the enclosure's hard drive slot. While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
    It is not a good idea to put fast SSDs into the optibay. System tries to negotiate at 6 Gbit, but it fails; disk is recognized but it couldn't even be formatted. I've waisted a lot of time to find a reason. After swapping SSD with original mac's HD both work properly, one at 6, another at 3 Gbit
    nicholas - Reply
    Good to know, thanks!
    zondervon -
    No problems here with a Samsung EVO in the optical bay. Only downside that is not really fast (80-90 mb/s) but amazing performances on booting time, shut off and opening programs.
    Mike - Reply
    I have to withdraw my comment. It is NOT a good idea to put a SATAIII SSD in the optical bay. It gives random freezes. Swapping it with a HD is indeed better. Better read/writes too. Only downside is that SMS won't work on the optical bay so treat your baby with care. Also Sleep issues might occur when placing a HD in the optical bay (a total freezing system). I already wasted a HD that was in the optical bay.
    Mike - Reply
    I've replaced the optibay with a samsung 840 pro but can't format it nor copy files (a few files work) to it. Do you suggest putting the HDD in the optibay instead? Did you clone the HDD to the SSD before swapping them? Will my Mac boot from the HDD the first time I boot even though it's in the optibay? I would really appreciate an answer, I've spent too many hours trying to figure it out!
    Carl - Reply
    Also had this same problem. Tried and failed a Samsung firmware upgrade. Ended up send drive back to Amazon.
    Andrew -
    Okay it seems like some models of MacBook Pro have issues with a fast (6Gbit/s) SSD in the optical bay. Even though my Mac says it offers 6Gbit on both bays it simply didn't work in the optical bay. So I switched places between the two drives and everything seems to work. My Mac booted from the old HDD in optical bay automatically and then I cloned it afterwards and changed the startup disk to the new one. As said before, don't put a fast SSD in the optical bay!
    Carl - Reply
    Hello Carl. What have you done after switching places between the two drives? Can you explain it with more details please? I have the HDD in the hard drive place, and an SSD in the optibay, and I have a lot of freeze / beachball. Thanks.
    danielsam55 -
    I'm on a Macbook pro 13" Late 2011.
    danielsam55 -
    I have the startup set to the SSD in the optibay.
    danielsam55 -
    I've already done it. switch the hard drives and reboot, that's all. Working without beachballs XD
    danielsam55 -
    My understanding is that SSDs will work (at 6Gbps) in the optical bay of late-2011 13" MBP models but not in late-2011 15" or 17" models and not in earlier 13" models. Are those of you reporting problems installing on late-2011 13" models (MD313LL/A [2.4Ghz] or MD314LL/A [2.8 GHz])?
    Steve - Reply
    I'm experiencing the same issues with the HDDs in the optical bay. I've tried multiple drives (WD caviar blue 3G and a Seagate 6G) with no luck thus far. I replaced the SATA cable and that didn't help with either drive. My SSD still works fine in the main bay but I would like the extra storage.
    For those of you who got the HDD in the optical bay working, which HDD (brand and model) did you use?
    My MBP is a Late 2011 15" (8.2)
    woestmab - Reply
    My understanding is that SSD in the optibay for 2011 MBPs will only work on the late-2011 13" model (not the 15" or 17"). I can confirm that it works in my late-2011 13" MBP. I have a Samsung EVO 500GB in my optibay (HGST 1TB in the hard drive bay) with no problems at all: negotiated link speed of 6Gbits for both drives and not beach balls or other slowdowns.
    Steve -
    I'm not trying to put an SSD in the optical bay. As I said, I've tried multiple HDDs but none of them seem to work. I know that it's possible to put an HDD in the optical bay because I bought the computer with one in it but it seems that none are recognized. I have tried multiple brands and speeds with no luck. I would like to know which specific model of HDD works in the late 2011 15" optical bay.
    Thanks
    woestmab -
    Many people have this problem and they all had the 2011 MBP model. The SATA controllers are both 6Gb/s on optic drive and HDD from 2012 (mid 2012 anyway). And of course we're talking about the non-retina. The last non-retina came out mid 2012.
    maniajami - Reply
    I just installed a Crucial M200 6 GB/s ssd in a 2012 15" Macbook Pro, working without issues. It seems the 2011 models are problematic.
    Martin G - Reply
    Whats the size of this caddy?
    Looks like no one has any clue. I can see following sizes:
    12.7mm universal
    12.7mm unibody
    9.5mm universal
    9.5mm unibody
    I have a macbook pro mid 2012 non retina
    saran3h.bansal - Reply
  24. Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure. Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
    Make sure you have removed the 2 screws at the end of your super driver unit and move it to your NewHD bay with the metal piece eye loop.
    Kamiiyu - Reply
    Normally with the HD enclosure there come a set of screws. use these to screw down the HD in the enclosure since you need to flip it up side down to reinstall it into the MBP
    Bart - Reply
    Here they picture Crucial as their choice, you can also find some great options at Samsung (it is what I installed and it works just as good if not better than the crucial I installed in my wife's iMac. here is their site http://www.samsung.com/us/computer/solid...
    Its just another great option. Also when installing SSDs make sure to enable TRIM support (crashes can and probably will occur if you don't) TRIM enabler is available free and the pro version is $10 http://www.cindori.org/software/trimenab... It is the easiest solution for this issue.
  25. Use two Phillips #1 screws to secure the drive to its enclosure. Use two Phillips #1 screws to secure the drive to its enclosure.
    • Use two Phillips #1 screws to secure the drive to its enclosure.
    With the particular drive bay adaptor I used, these attachment screws were already fitted to the adaptor but were found at the sides, not underneath. Indeed, the adaptor had no screw holes on the underside.
    jjsanderson - Reply
    At first I couldn't get my machine to even turn on - thought it was the battery connector, but in the end I just had to reset the SMC. (http://support.apple.com/kb/ht3964 - see "Resetting the SMC on portables with a battery you should not remove on your own").
    mainframe - Reply
  26. Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
    I have the drive installed with this bay, but the drive does not appear in the Disk Utility. I see a 'Nvidia MCP79 AHCI' in the system information, but no drive listed with it. Is there some special driver needed to get the MCP to see the drive?
    toddfletcher - Reply
    Replaced the optical with hdd, as well as replaced the hard drive with an ssd. Now I get the circle with a line through it. But, when I hold the option key down, it gives me both hard drives, PLUS, the thumb drive I have in the USB port with a Mountain Lion installer. It even shows the recovery disks, but gives me the circle with the line when I choose one. Any help is appreciated.
    claude - Reply
    Mate,
    My mbp shipped with OS 10.8, and I had upgraded twice to 10.10
    I've a 10.7 USB which upgraded my old MBP.
    My plan today was to boot with my new ssd, my time machine back up and the Lion usb plugged in.
    I would then click on the Lion usb, and tell it to put the OS and time machine back up on the ssd.
    So I help down ALT and when it started it gave me the options of the usual Mac internal or the Lion USB.
    I clicked Lion, but instead of taking me to the install options (Disk utility, restore from time machine etc etc) it gave me that grey circle with a diagonal line through it. The no entry sign - grey on grey - that I think you have.
    Some googling said that it is because I was trying to usb a 10.7 install on a MBP that shipped 10.8
    You can't go back, apparently.
    So if any of the OSs are older than the mac you got, you will get this error. The grey in grey no entry.
    I just cloned my HDD to my ssd (Carbon copy cloner free 30 day trial) using an external stat-usb3 wire and all is good.
    Rory -
    it does not recognize the hard drive in the enclosure, what should i do?
    elvin00 - Reply
    simple question, how do I use the removed drive to play a DVD? Why don't I just use digital media...yadayada...I know. I'm currently in the hospital, did this drive swap for busy work. The littles want to watch an old DVD and I can't solve the issue.
    gator6 - Reply
    This will give you instructions on how to get your DVD player to work in an external enclosure: http://macenstein.com/default/2011/07/ho...
    Steve -
    I have a 17" Macbook Pro6,1 unibody with an Intel Core i5, 2.53GHz. I was successful installing a 250GB SSD in the DVD bay, and I'm able to boot from it. I did this by first installing OS X 10.9.4 on the SSD mounted into an external HD case, testing the system to see if it would boot up into the SSD, then installing the SSD and carrier in the DVD drive bay. The system now boots up from the SSD with no problems. If you are having installation problems, I recommend trying this method.
    roger hall - Reply
    This is really for step 23: reassembly
    You can not get the orginal screws back in to hold the new optical drive replacement in place because there is a black plastic filler running along the front edge of the part. There is no place for the screw head to go. I had to remove some of the plastic to get the machine reassembled. Whoever tested this overlooked what I think is a major problem. How many macbook pros are out there with only one (maybe two if you're lucky) screw holding this thing in place?
    I got extra screws and have no idea why. The bits included in the kit are poor and don't work on most of the screws. I had to use my own tools instead.
    eetech - Reply
    Hi,
    I'm using a 13' MBP mid 2010 and I just swapped my HDD for a SSD. Al works perfectly fine!
    So i bought the unibody laptop dual drive (from iFixit) and replaced the optical drive for the original HDD from my MBP. The installation with this guide went perfectly, however, the HDD is not recognized in disk utility.
    I put the old HDD back on the original HDD bay, the HDD boots and works. I placed back the optical drive in the optical bay, also works. But when i put the HDD in the unibody laptop dual drive (iFixit), it is not recognized via the USB-port(however, the HDD starts spinning) or when installed in the optical bay.
    So i think there is a software issue where my MBP does not recognize a HDD in the optical bay. Is there a way to force the OS to look for storage/HDD via the optical bay STATA cable?
    All help is welcome!
    Thanks,
    Leon
    Leon - Reply
    Leon: did you fix your issue? I'm facing the same problem.
    Rafael Borges -
    No, afraid not..
    Leon -
    also having the same problem, not recognizing second hdd
    cmaizan -
    Same here: installed original hdd in optical bay and it won't mount. Tried it using the sata cable on different computer, and the drive spins, but doesn't mount either. Would love to get a fix (or at least an explanation) for this. The whole point was to add extra storage, but so far, no dice.
    Simon Abrams -
    Did you ever find a solution?
    I installed mine, but the ssd I'm using was a bootable usb running Yosemite, and now that I plugged it in, I'm getting a circle with the slash through it when I try to boot to it, and I can't unmount it or reformat it from the recovery Disk Utility or in Mountain Lion on the stock hdd still inside.
    drguttridge -
    Same issue here unfortunately... new SSD in primary slot is recognized fine and allowed me to install OS X with no issues from USB. However, both during the install when booting from USB and post-install within the full El Capitan OS, I simply do not see any '2nd' hard drive in the system - for the record I just reused the same 500GB HDD that came with my MBP; and I ran the exhaustive System Profiler tests prior to doing any work to ensure I'd have no HW issues/surprises. Sure enough,. I can hear the mechanical drive churning as the power runs to it, so I know it's hooked up okay. For some reason the drive just isn't being recognized by the Mac OS. Hoping someone can help me resolve this so I don't feel bad about spending the [extra] money on the iFixit enclosure system vs. one of the cheaper alternatives I found online, sigh... Any help would be much appreciated, thanks!
    Brian M -
    Figured I'd reply to my own message just above for those interested or following my situation. The 'churning' I heard was actually the left fan inside the system, which I managed to disassemble so I could lubricate the sleeve bearing with a touch of mineral oil - now it's as quiet as ever and works great. Also, I ordered a replacement optical SATA adapter cable from iFixit and this resolved my issue of accessing the hard drive moved to the optical slot inside the dual drive enclosure. Long story short - all of my issues are resolved thanks to some disassembly/repair work and new parts from iFixit!
    Brian M -
    Same problem happens, i don’t know how to fix that as well. Anyone has any idea? Thanks
    jimmychan1007 -
    Hi!
    I followed the tutorial and everything works fine when I use an HDD 320 go but when I use the new HDD I bought which is an Hitachi 1T 7200T 2.5 P I have some trouble. The disk utily takes a long time to recognize the new hard drive and then starts not responding.
    I tought my new HDD might be broken but when I use it with an external portable HDD Enclosure it works fine...
    Any ideas?
    Thanks!
    Julie
    Julie Odeursa - Reply
    I do believe the max size HDD is a 750GB. 1TB might be too big. Though the ONLY place I found this stated was on iFixit. No where else.
    zondervon -
    I just have finished installing second SSD to my MBP (unibody 15` 2010).
    First one was changed like one year ago. Samsung 500GB SSD. It is in my HDD bay and I'm running system from it.
    Today I put a new Samsung 1TB 850 Evo 1 SSD in to my optic bay.
    I encounter problem with SSD not recognized by Finder.
    But It was recognized by Disk Utility.
    What I did was I erase new SSD by Disk Utility. Then the new partition was created and now It has been seen by Finder.
    So If you see it in Disk Utility just erased it.
    Some extra info in under this link--> https://discussions.apple.com/docs/DOC-4...
    Wish you all luck :)
    rybafly - Reply
    Hi all,
    I did this and all seemed to be working fine, both drives showed up and all was good then about 20 minutes later i got a message saying that "the drive had been ejected incorrectly" or something like that. The drives have now disappeared from finder and Disk Utility. I took the SSD out of the superdrive caddy and put it in an external USB3 caddy, it's working fine. I even left this connected over night (all OK). This morning i put the SSD back into my Late 2011 MacBook and the same thing happened, 20ish minutes and then the eject message... Have i missed something?
    Any help would be very much appreciated.
    Steven Vacher - Reply
    Dear iFixit
    I changed my Hdd with an ssd using this guide. My hdd is now in a caddy where the optical drive used to be.
    I can see my original drive ( Toshiba 500GB ) in the disk utility-app, but i can't reach my data on it.
    When i take it out of the caddy again and put it in a external Hdd case, i can read it perfectly fine.
    So there is nothing wrong with the hdd or the connection.
    Is this a problem i can fix with software?
    Thx for the help!
    Jonas Lesage - Reply
    Those were Phillips #00 in my case, not #0, on the small metal mounting bracket.
    Oliver Creighton - Reply
  27. Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable. Align the cable's SATA connector with the drive's port and plug in securely. Plug the USB connector into your laptop and your optical drive is ready for use.
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
    There is a small metal button in the front of the drive and you can use that to eject the drive if you were wondering.
    Joseph Landry - Reply
    my drive’s connector is nothing like that, and I’m wondering is it possible to connect it to another computer?
    grantdavis - Reply
    Outstanding instructions!!
    syellon - Reply
25 other people completed this guide.
Brittany McCrigler
82,922 Reputation
132 Guides authored
6 Comments
Is there any drivers or anything that needs to be done on the Mac itself to install this hard drive? Can you use this hard drive to install applications onto as well?
Nathan - Reply
Here's something important to be aware of. DVD Player will not function without a physical dvd drive installed. This is even if you use DVD image files, which I do. The explanation I got is that without that optical drive DVD Player can't check regions. If you want to watch DVDs on your mac mini, even DVD image files, don't remove the optical drive.
Bob Church - Reply
Or, if you want to play dvd files just use vlc player... if vlc can't play it, it can't be played.
cort -
Just added a 500 gig HD I had laying around to a 2007 Mac Mini I got on eBay.....worked like a charm. Thanks iFixit!
Alexsander Jevtich - Reply
although my optical bay hard drive enclosure did not use or have the bracket shown above with two Phillips #0 screws. And the hard drive had a different attachment system. The screws did not come in from the bottom. They came in from the side....no matter still a great solution.
I tried to open up the bottom of the mac mini but, I ended up with a bent pry tool
Alden Hughes - Reply
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 113
All Time: 31,431
