Dell Inspiron 530 Power Supply Replacement
  1. Dell Inspiron 530 Power Supply Replacement, Side Panel: step 1, image 1 of 1
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Dell Inspiron 530 Power Supply Replacement: step 2, image 1 of 1
    • Slide the side panel towards the back and remove.
  3. Dell Inspiron 530 Power Supply Replacement, Power Supply: step 3, image 1 of 1
    • Locate the power supply in upper-back corner of the case.
  4. Dell Inspiron 530 Power Supply Replacement: step 4, image 1 of 1
    • Remove the two power cables from the motherboard.
  5. Dell Inspiron 530 Power Supply Replacement: step 5, image 1 of 1
    • Remove the power cables from the CD/DVD drive and hard drive.
  6. Dell Inspiron 530 Power Supply Replacement: step 6, image 1 of 1
    • Locate and remove the four Philips #0 8.9 mm screws on the outside of the case.
  7. Dell Inspiron 530 Power Supply Replacement: step 7, image 1 of 1
    • Gently remove the power supply from the case.
17 other people completed this guide.
Doug Howe
2,161 Reputation
2 Guides authored
Cal Poly, Team 6-8, Regan Fall 2011 Member of Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
4 Members
18 Guides authored
One Comment
Cuantos Watts de una Power Supply la Inspiron 530 soporta?
Baldwin E. C. Rafael - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 27
All Time: 26,378
