Introduction
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
The battery hatch is on the bottom of the camera. CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
Can the hatch be replaced. The piece that holds the hatch is broken.
alisonbforman46 - Reply
This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
    • This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
    • The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
  • Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
  • Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
  • Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
  • Open the battery cover.
  • Using the iPod tool, push up gently around all edges of the camera.
6 other people completed this guide.
Zach
237 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 7,704
