Introduction
Hi!
This is certainly a job you can do yourself, and it doesn't break any seal so it's even warranty-safe.
Just make sure you use a screwdriver that fits perfectly! otherwise you'll end up damaging those little screws.
undo screw near the letter 'o' from 'open' that's indicated on the bottom left of the camera
  • undo screw near the letter 'o' from 'open' that's indicated on the bottom left of the camera
Undo screw as indicated by the red arrow.
  • Undo screw as indicated by the red arrow.
  • for this, you need to lift the rubber covers over the data connectors
New Battery = Faster iPhone
Fix Kits starting at $16.99
now you can simply slide out the carrier for the 'Date & Time Battery'
  • now you can simply slide out the carrier for the 'Date & Time Battery'
now you have access to the battery.
  • now you have access to the battery.
  • The type is CR1616, 3V , lithium type, original brand as supplied by canon is Maxell.
  • Battery goes in with the +positive side down (as pictured)
3 other people completed this guide.
Hans Bruch jr
667 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 10,427
