Introduction
L'aggiornamento della memoria RAM garantisce un immediato aumento della velocità.
Allentare la vite con testa a croce al centro dello sportello di accesso.
Rimuovere lo sportello di accesso dall'iMac.
Mediante la punta di un inseritore, estrarre le linguette di plastica nera della memoria RAM dall'apposito alloggiamento.
Tirare la linguetta di plastica nera dall'iMac per espellere il modulo RAM.
Pulling plastic tabs isn’t releasing the old ram board. How to get this out when black tabs don’t work
Black plastic tabs not releasing the old ram cards. How to get out?
Tenere il modulo di memoria RAM dai bordi ed estrarlo dal relativo connettore.
graphic is not for the proper model iMac. For this series iMac there is only 1 pair (2 total) of memory slots, this graphic displays 2 pairs (4 total). Also there is a lever to eject the ram not plastic tabs.
Per riassemblare il dispositivo, seguire queste istruzioni in ordine inverso.
53 other people completed this guide.
Special thanks to these translators:
100%
Jasper Fleischhauer is helping us fix the world! Want to contribute?
Start translating ›
5 Comments
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
PH2 head necessary to remove screw.
airshack - Reply
Mine was as written, a PH1.
tpivo - Reply
