Introduction
Utilisez ce guide pour mettre à niveau votre RAM et optimiser instantanément la vitesse.
Débranchez le cordon d'alimentation de votre iMac et tous les éventuels périphériques.
Posez l'iMac à l'envers sur une surface propre et douce.
Desserrez les trois vis Phillips par lesquelles la trappe d'accès est fixée en dessous de votre iMac.
Retirez la trappe d'accès.
Libérez la languette en plastique noire de l'emplacement de la RAM.
Tirez sur la languette en plastique en dessous de votre iMac pour éjecter le(s) module(s) de ce côté-ci du compartiment de la RAM.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
132 other people completed this guide.
Special thanks to these translators:
100%
Fabienne Detoc is helping us fix the world! Want to contribute?
Start translating ›
5 Comments
Considering cautions against mixing RAM it would seem my 2009 imac can only be helped by ripping out original 4, 1G Ram modules and replacing with 4 @moreG as "cheapest "way to upgrade which seems ridiculous compared to changing one or 2 modules. Is this another stupidity of our computer world?
Harol Smage
Thank you this worked really well!
When inserted new 2x4GB modules in addition to the original 2x2GB modules to iMac mid 2011, it was only beeping on power off. Tried to swap all module placements around couple of times before they were all accepted. Now with 12GB total ram.
I'm assuming that I could replace all 4 ram slots with 4x8gb chips above?? Would this work?
iMac (21.5-inch, Mid 2011) 2.5 GHz Intel Core i5
current ram 12 GB 1333 MHz DDR3
I want to replace 2 current chips if not all 4 with this PC3-10600 8 GB RAM Chip
I have just removed 2 x 2 GB ram modules and replaced with 2 x 4GB?
'Could' the 2x2GB modules be stuck back in also, or no?
