This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
La mise à niveau de la RAM sur le Mac mini mi-2010 est une opération simple qui ne nécessite pas d'outils.
Placez vos pouces dans les deux creux du capot inférieur.
Faites pivoter le capot inférieur dans le sens contraire des aiguilles d'une montre jusqu'à ce que le petit point blanc peint sur le capot soit aligné sur le repère correspondant du boîtier extérieur.
Écartez les deux clips de chaque côté de la barrette de RAM simultanément pour libérer cette dernière.
Lorsque la barrette de RAM se soulève, sortez-la de son emplacement en la levant bien droit.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
100 other people completed this guide.
Special thanks to these translators:
60%
Fabienne Detoc is helping us fix the world! Want to contribute?
Start translating ›
15 Comments
Do the RAM chips have to be paired, or could I replace a one gig bar with a 4 gig bar?
Thanks for any hints!
They don't need to be paired, although that is the optimum. Just remember, it is best to make sure they are the same speed, or the Mac will just operate both RAMs at the speed of the slowest stick. For example, if you have 2x 1GB PC8500 sticks in there, and you replace one of them with a 4GB PC10600 stick (fastest speed this Mac Mini will run) you will get a benefit form the extra memory, but not the full speed upgrade as both RAMs will operate at the speed of the 8500 stick. Does that make sense? So replacing both with 2x 2GB PC10600 will give you better performance.
This Mac Mini will run PC10600 RAM sticks, although I believe only 4GB per slot.
This Mac can run 16GB of RAM, mine does. Just FYI.
Interesting. I want to try that.
