Insignia NS-CSPBTHOL-R Battery Replacement
  1. Insignia NS-CSPBTHOL-R Battery Replacement, Battery: step 1, image 1 of 1
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
  2. Insignia NS-CSPBTHOL-R Battery Replacement: step 2, image 1 of 1
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
  3. Insignia NS-CSPBTHOL-R Battery Replacement: step 3, image 1 of 2 Insignia NS-CSPBTHOL-R Battery Replacement: step 3, image 2 of 2
    • Pull the grated panel off.
  4. Insignia NS-CSPBTHOL-R Battery Replacement: step 4, image 1 of 2 Insignia NS-CSPBTHOL-R Battery Replacement: step 4, image 2 of 2
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  5. Insignia NS-CSPBTHOL-R Battery Replacement: step 5, image 1 of 2 Insignia NS-CSPBTHOL-R Battery Replacement: step 5, image 2 of 2
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
  6. Insignia NS-CSPBTHOL-R Battery Replacement: step 6, image 1 of 1
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
  7. Insignia NS-CSPBTHOL-R Battery Replacement: step 7, image 1 of 2 Insignia NS-CSPBTHOL-R Battery Replacement: step 7, image 2 of 2
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
4 other people completed this guide.
Judith Villegas
312 Reputation
2 Guides authored
USF Tampa, Team 12-6, Eyestone Spring 2017 Member of USF Tampa, Team 12-6, Eyestone Spring 2017
USFT-EYESTONE-S17S12G6
3 Members
4 Guides authored
4 Comments
excellent, was able to make my Insignia speaker work, which didn’t work for years. The battery had been good. removing and reassembling made the unit work!
Uthayaraj - Reply
What type of battery does it use?
Michelle McFadden - Reply
Did you ever find out what battery it takes?
Steve Skinner -
I found out the correct replacement battery is 18650, 3.7V/2000mAH
Steve Skinner -
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 6
All Time: 2,300
