Introduction
The steps provided will walk you through the necessary replacement for the screen. Complete the prerequisites before performing these tasks.
Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury. Place the device on a firm surface with the device screen facing down. Place the device on a firm surface with the device screen facing down.
  • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
  • Place the device on a firm surface with the device screen facing down.
Remove 2, 6.1 mm Phillips J000 screws from the back of the device. If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
  • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
I just checked and there are no screw holes on my Insignia 11.6” tablet!
Mugsys RapSheet - Reply
Using a plastic tool and the plastic card, gently pry off the back cover. Using a plastic tool and the plastic card, gently pry off the back cover. Using a plastic tool and the plastic card, gently pry off the back cover.
  • Using a plastic tool and the plastic card, gently pry off the back cover.
How many locking tabs are there? I see one in the corner.
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery. Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery. Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Unplug the 2 speaker's connection from the motherboard.
  • Unplug the 2 speaker's connection from the motherboard.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Peel the yellow tape off from on top of the electrical connectors. Peel the yellow tape off from on top of the electrical connectors.
  • Peel the yellow tape off from on top of the electrical connectors.
Flip up the black cover pieces to expose the  3 electrical connectors. Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  • Flip up the black cover pieces to expose the 3 electrical connectors.
  • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard. Remove the black camera connector by gently prying on it until it unhooks. Remove the black camera connector by gently prying on it until it unhooks.
  • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
  • Remove the black camera connector by gently prying on it until it unhooks.
Using tweezers, remove the microphone from the the plastic cover. Using tweezers, remove the microphone from the the plastic cover.
  • Using tweezers, remove the microphone from the the plastic cover.
Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
  • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
  • Motherboard pops out.
Remove battery by prying off with card. Remove battery by prying off with card. Remove battery by prying off with card.
  • Remove battery by prying off with card.
Peel back the copper color electrical connector with blue opening tool. Peel back the copper color electrical connector with blue opening tool.
  • Peel back the copper color electrical connector with blue opening tool.
Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
  • Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
  • Bracket will then come off.
Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
  • Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
Remove screen from case by prying with a card. Remove screen from case by prying with a card.
  • Remove screen from case by prying with a card.
3 Comments
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
Charles Kinnison - Reply
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
Joshua Francis -
mine doesn’t look like that…
Joshua Francis - Reply
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 129
All Time: 1,580
