Imation Superdisk USB Drive Metal Casing Replacement
  1. Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: step 1, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: step 1, image 2 of 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Metal Casing Replacement: step 2, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 2, image 2 of 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Metal Casing Replacement: step 3, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 3, image 2 of 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Metal Casing Replacement: step 4, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 4, image 2 of 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Metal Casing Replacement: step 5, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 5, image 2 of 2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Metal Casing Replacement: step 6, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 6, image 2 of 2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: step 7, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: step 7, image 2 of 2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Metal Casing Replacement: step 8, image 1 of 2 Imation Superdisk USB Drive Metal Casing Replacement: step 8, image 2 of 2
    • Slide disk drive out of metal casing.
Ryan
1 Reputation
1 Guide authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 353
