IINE Retro Pocket Joystick Replacement
    1. IINE Retro Pocket Joystick Replacement, Remove the screws: step 1, image 1 of 3 IINE Retro Pocket Joystick Replacement, Remove the screws: step 1, image 2 of 3 IINE Retro Pocket Joystick Replacement, Remove the screws: step 1, image 3 of 3
      • Set the controller down on your working surface.
      • Flip the controller over so the back of the controller is facing up, with the shoulder buttons facing away from you.
      • Use a Phillips #1 screwdriver to remove the four black 7.5mm screws from the corners of the back plate.
      Ask FixBot
    2. IINE Retro Pocket Joystick Replacement, Remove the back plate: step 2, image 1 of 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: step 2, image 2 of 3 IINE Retro Pocket Joystick Replacement, Remove the back plate: step 2, image 3 of 3
      • Use the tip of an opening pick to separate the back plate. Start at the bottom corner, and pry downwards.
      • As you make your way toward the center, you will eventually disengage the retaining clips located on either side of the status LED array.
      • Be careful not to damage the retaining clips. they're small and thin, and may break easily.
      • Lift the back plate up and away from you, and set it aside.
      Ask FixBot
    3. IINE Retro Pocket Joystick Replacement: step 3, image 1 of 1
      • Once the back plate is removed, you now have access to the internals of the controller.
      Ask FixBot
    1. IINE Retro Pocket Joystick Replacement, Disconnect the battery: step 4, image 1 of 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: step 4, image 2 of 3 IINE Retro Pocket Joystick Replacement, Disconnect the battery: step 4, image 3 of 3
      • For safety and to prevent damage, disconnect the battery before continuing.
      • Locate the battery connector.
      • Use a pair of tweezers to carefully push on the notches of the battery connector and disconnect it from the socket.
      • Do not pull on the wires!
      Ask FixBot
    2. IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: step 5, image 1 of 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: step 5, image 2 of 3 IINE Retro Pocket Joystick Replacement, Disconnect the right joystick: step 5, image 3 of 3
      • Locate the ZIF connector of the right joystick.
      • Use a pair of tweezers to flip up the black flap of the ZIF connector and unlock it.
      • Disconnect the joystick cable by carefully pulling it straight out of the connector.
      Ask FixBot
    3. IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: step 6, image 1 of 2 IINE Retro Pocket Joystick Replacement, Unscrew the right joystick: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the right joystick.
      Ask FixBot
    4. IINE Retro Pocket Joystick Replacement, Remove the right joystick: step 7, image 1 of 2 IINE Retro Pocket Joystick Replacement, Remove the right joystick: step 7, image 2 of 2
      • Lift up the joystick module and set it aside.
      Ask FixBot
    5. IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: step 8, image 1 of 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: step 8, image 2 of 3 IINE Retro Pocket Joystick Replacement, Disconnect the left joystick: step 8, image 3 of 3
      • Locate the ZIF connector of the left joystick.
      Ask FixBot
    6. IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: step 9, image 1 of 2 IINE Retro Pocket Joystick Replacement, Unscrew the left joystick: step 9, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two black 3.5mm screws that secure the left joystick.
      Ask FixBot
    7. IINE Retro Pocket Joystick Replacement, Remove the left joystick: step 10, image 1 of 2 IINE Retro Pocket Joystick Replacement, Remove the left joystick: step 10, image 2 of 2
      Ask FixBot
Once the controller is fully reassembled, connect it to your Nintendo Switch and calibrate the new joystick.
2 other people completed this guide.
Aardimus
318 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 90
All Time: 427
