Hyundai Accent Rear Seat Cushion Replacement
  1. Hyundai Accent Rear Seat Cushion Replacement, Remove the rear seat retaining bolt: step 1, image 1 of 2 Hyundai Accent Rear Seat Cushion Replacement, Remove the rear seat retaining bolt: step 1, image 2 of 2
    • There is a single bolt holding the rear seat cushion in place. It's located in the center of the seat at the rear but can't be seen without compressing the seat.
    Ask FixBot
  2. Hyundai Accent Rear Seat Cushion Replacement: step 2, image 1 of 1
    • Using a 12 mm socket and a short extension, remove the mounting bolt.
    Ask FixBot
  3. Hyundai Accent Rear Seat Cushion Replacement, Disconnect the front latches: step 3, image 1 of 2 Hyundai Accent Rear Seat Cushion Replacement, Disconnect the front latches: step 3, image 2 of 2
    • There are two latches holding the front of the seat cushion that just need to be popped loose to finish removing the seat.
    • Grasp the front edge of the seat and pull up firmly to disconnect the latches.
    Ask FixBot
  4. Hyundai Accent Rear Seat Cushion Replacement: step 4, image 1 of 1
    • Pull the seat cushion forward, then it can be removed.
    Ask FixBot
To reassemble your car, follow these instructions in reverse order.
Jerry Wheeler
94,858 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 53
All Time: 134
