Hyundai Accent Fuel Pressure Relief Technique
  1. Hyundai Accent Fuel Pressure Relief Technique, Hyundai Accent Fuel Pressure Relief Technique: step 1, image 1 of 1
    • Facing the front of the car, the underhood fuse box is located on the right hand side, between the battery and the fender.
    Ask FixBot
  2. Hyundai Accent Fuel Pressure Relief Technique, Open the fuse box: step 2, image 1 of 2 Hyundai Accent Fuel Pressure Relief Technique, Open the fuse box: step 2, image 2 of 2
    • Press the tab on the front of the fuse box.
    • And release the tab on the rear side of the fuse box.
    Ask FixBot
  3. Hyundai Accent Fuel Pressure Relief Technique, Disable the fuel pump: step 3, image 1 of 1
    • You can remove the fuel pump fuse or the fuel pump relay; either one will accomplish your purpose.
    • Fuel pump fuse
    • Fuel pump relay
    Ask FixBot
  4. Hyundai Accent Fuel Pressure Relief Technique: step 4, image 1 of 2 Hyundai Accent Fuel Pressure Relief Technique: step 4, image 2 of 2
    • In this example, we are pulling the fuse rather than the relay, but again, either will do the job.
    • Using the fuse puller found in the fuse box, remove the 15A fuel pump fuse and set it aside.
    Ask FixBot
  5. Hyundai Accent Fuel Pressure Relief Technique, Start the car: step 5, image 1 of 2 Hyundai Accent Fuel Pressure Relief Technique, Start the car: step 5, image 2 of 2
    • Put the key in the ignition and start the car. There will usually be enough residual pressure in the line to allow the car to start.
    Ask FixBot
  6. Hyundai Accent Fuel Pressure Relief Technique, Run the car until the engine dies: step 6, image 1 of 2 Hyundai Accent Fuel Pressure Relief Technique, Run the car until the engine dies: step 6, image 2 of 2
    • Depending how long it's been since the car was run last, there may be quite a bit of pressure in the lines, which can let the car run for as much as three minutes, so be patient and let the car idle until it dies on its own.
    • Turn the car off and remove the key.
    Ask FixBot
Don't forget to reinstall the fuse or relay once your work is complete.
Jerry Wheeler
94,834 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 54
All Time: 67
