Hyundai Accent Camshaft Position Sensor Replacement
  1. Hyundai Accent Camshaft Position Sensor Replacement, Remove the engine cover: step 1, image 1 of 2 Hyundai Accent Camshaft Position Sensor Replacement, Remove the engine cover: step 1, image 2 of 2
    • Grasp the engine cover by the front edge.
    • Give it a firm yank upward.
    Ask FixBot
  2. Hyundai Accent Camshaft Position Sensor Replacement: step 2, image 1 of 2 Hyundai Accent Camshaft Position Sensor Replacement: step 2, image 2 of 2
    • Grab the rear edge of the cover.
    • Yank it upward.
    Ask FixBot
  3. Hyundai Accent Camshaft Position Sensor Replacement: step 3, image 1 of 1
    • The engine cover has been removed.
    Ask FixBot
  4. Hyundai Accent Camshaft Position Sensor Replacement, Locate the CMPSes: step 4, image 1 of 2 Hyundai Accent Camshaft Position Sensor Replacement, Locate the CMPSes: step 4, image 2 of 2
    • The camshaft position sensors are found next to the high pressure fuel pump.
    • The intake camshaft position sensor.
    • And the exhaust camshaft position sensor.
    Ask FixBot
  5. Hyundai Accent Camshaft Position Sensor Replacement, Disconnect the intake CMPS: step 5, image 1 of 2 Hyundai Accent Camshaft Position Sensor Replacement, Disconnect the intake CMPS: step 5, image 2 of 2
    • Press the locking tab firmly.
    • Pull the connector off.
    Ask FixBot
  6. Hyundai Accent Camshaft Position Sensor Replacement, Disconnect the exhaust CMPS: step 6, image 1 of 2 Hyundai Accent Camshaft Position Sensor Replacement, Disconnect the exhaust CMPS: step 6, image 2 of 2
    • Press firmly on the locking tab.
    Ask FixBot
  7. Hyundai Accent Camshaft Position Sensor Replacement, Unbolt the intake CMPS: step 7, image 1 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Unbolt the intake CMPS: step 7, image 2 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Unbolt the intake CMPS: step 7, image 3 of 3
    • Using a 10mm socket, remove the retaining bolt.
    Ask FixBot
  8. Hyundai Accent Camshaft Position Sensor Replacement, Unbolt the exhaust CMPS: step 8, image 1 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Unbolt the exhaust CMPS: step 8, image 2 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Unbolt the exhaust CMPS: step 8, image 3 of 3
    Ask FixBot
  9. Hyundai Accent Camshaft Position Sensor Replacement, Remove the intake CMPS: step 9, image 1 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Remove the intake CMPS: step 9, image 2 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Remove the intake CMPS: step 9, image 3 of 3
    • Grasp the sensor and pull straight up to remove it.
    Ask FixBot
  10. Hyundai Accent Camshaft Position Sensor Replacement, Remove the exhaust CMPS: step 10, image 1 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Remove the exhaust CMPS: step 10, image 2 of 3 Hyundai Accent Camshaft Position Sensor Replacement, Remove the exhaust CMPS: step 10, image 3 of 3
    Ask FixBot
Apply engine oil to the O-ring before installing the sensor.
Torque specifications: 7.8 - 11.8 N.m / 0.8 - 1.2 kgf.m / 5.8 - 8.7 lb-ft
Note that most torque wrenches specified in foot-pounds are not very accurate at low settings like these. If possible, use a wrench calibrated in inch-pounds. Use 70-105 lb-in to torque.
Jerry Wheeler
94,858 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 55
Past 30 Days: 178
All Time: 663
