Hyundai Accent CVVT Oil Control Valve Replacement
  1. Hyundai Accent CVVT Oil Control Valve Replacement, Remove the engine cover: step 1, image 1 of 2 Hyundai Accent CVVT Oil Control Valve Replacement, Remove the engine cover: step 1, image 2 of 2
    • Grasp the engine cover by the front edge.
    • Give it a firm yank upward.
    Ask FixBot
  2. Hyundai Accent CVVT Oil Control Valve Replacement: step 2, image 1 of 2 Hyundai Accent CVVT Oil Control Valve Replacement: step 2, image 2 of 2
    • Grab the rear edge of the cover.
    • Yank it upward.
    Ask FixBot
  3. Hyundai Accent CVVT Oil Control Valve Replacement: step 3, image 1 of 1
    • The engine cover has been removed.
    Ask FixBot
  4. Hyundai Accent CVVT Oil Control Valve Replacement, Unplug the oil control valve electrical connector: step 4, image 1 of 3 Hyundai Accent CVVT Oil Control Valve Replacement, Unplug the oil control valve electrical connector: step 4, image 2 of 3 Hyundai Accent CVVT Oil Control Valve Replacement, Unplug the oil control valve electrical connector: step 4, image 3 of 3
    • Press the tab on the electrical connector and unplug the OCV.
    Ask FixBot
  5. Hyundai Accent CVVT Oil Control Valve Replacement, Remove the retaining bolt: step 5, image 1 of 2 Hyundai Accent CVVT Oil Control Valve Replacement, Remove the retaining bolt: step 5, image 2 of 2
    • Using a 10mm socket, remove the bolt securing the OCV.
    Ask FixBot
  6. Hyundai Accent CVVT Oil Control Valve Replacement, Remove the oil control valve: step 6, image 1 of 3 Hyundai Accent CVVT Oil Control Valve Replacement, Remove the oil control valve: step 6, image 2 of 3 Hyundai Accent CVVT Oil Control Valve Replacement, Remove the oil control valve: step 6, image 3 of 3
    • Grasp the OCV and with a twisting motion, pull the valve out of its housing.
    Ask FixBot
  7. Hyundai Accent CVVT Oil Control Valve Replacement: step 7, image 1 of 1
    • The oil control valve has been removed.
    Ask FixBot
Jerry Wheeler
94,834 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 107
All Time: 159
