Shop the Holiday Gift Guide
Hyper Mega Tech! Taito Super Pocket Back Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
8
Past 30 Days:
67
All Time:
301
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Hyper Mega Tech! Super Pocket is experiencing issues, removing the back panel is typically the first step to access, clean, or replace internal components like the battery, speaker, buttons, and mainboard. The back panel serves as the primary structural shell, protecting the internal electronics from dust, debris, and minor impacts.
Use this step-by-step guide to safely remove the back cover. Before beginning, ensure the device is powered off and completely disconnected from any external power sources.
Tools
    1. Hyper Mega Tech! Taito Super Pocket Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Power the device off before starting the disassembly process.
      Ask FixBot
    2. Hyper Mega Tech! Taito Super Pocket Back Panel Replacement: step 2, image 1 of 2 Hyper Mega Tech! Taito Super Pocket Back Panel Replacement: step 2, image 2 of 2
      • Face the back of the device, then remove the Super Pocket gaming cartridge from the device.
      Ask FixBot
    3. Hyper Mega Tech! Taito Super Pocket Back Panel Replacement: step 3, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the four 2 mm screws from the four corners.
      Ask FixBot
    4. Hyper Mega Tech! Taito Super Pocket Back Panel Replacement: step 4, image 1 of 2 Hyper Mega Tech! Taito Super Pocket Back Panel Replacement: step 4, image 2 of 2
      • Face the front of the device and use the iFixit opening tool to lift the front panel from the back cover.
      • Be careful not to pull the two sides quickly, as they are connected by a battery cable, and it can be damaged if pulled too hard.
      Ask FixBot
    5. Hyper Mega Tech! Taito Super Pocket Back Panel Replacement: step 5, image 1 of 1
      • Disconnect the battery cord connecting the two sides with tweezers.
      Ask FixBot
Author
with
Isabela Castro
607 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 67
All Time: 301
