Remove back cover. Remove back cover. Remove back cover.
  • Remove back cover.
Remove small signal cable.
  • Remove small signal cable.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Twist off those nine screws and remove the bracket. Twist off those nine screws and remove the bracket.
  • Twist off those nine screws and remove the bracket.
There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly. There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly. There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly.
  • There is adhesive under the vibration motor, so release the connector and pry up to remove the assembly.
Sophia
37,463 Reputation
107 Guides authored
Past 24 Hours: 5
Past 7 Days: 8
Past 30 Days: 18
All Time: 1,300
