Introduction
Use this guide to replace the Display assembly of your Huawei P8 Lite including the frame.
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
When all clips are open, remove the back cover from the rest of the phone.
The back panel is really really easy to brake, be careful :)
In my mobile phone the back panel was kept in place also from 2 strips of bi-adhesive tape. Pull gently to detach it to remove the panel.
right. it has 4 strips of adhesive tape
To facilitate the detachment of these double-sided tapes, I recommend heating with a hairdryer along the edges of the back cover, especially at the four corners.
Nicola -
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
The 4 screws wich hold down the lower part of the loudspeaker are Torx screws for me. But it's a French Huawei, doin' nothing like the others :)
Die Wasserschadenindikatoren sitzen unter dem Mainboard. Bei den Aufklebern auf den TORX handelt es sich um Garantiesiegel.
Danke für den Hinweis, wurde so übernommen.
Bonjour, il vous faut un tournevis ou un embout cruciforme #00 pour dévisser une vis cruciforme #00. Bonne réparation !
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
Then remove the top cover.
An der Linken Plastikabdeckung sind die Kontakte dran geklebt!
EN: The lateral small plastic piece is sticked to the flex of the side buttons. Take care
Pry off the vibrator using a plastic opening tool.
Use the pull tab as seen here in the battery guide to remove one of the adhesives strips underneath the battery.
Use an opening pick or spudger to carefully pry the battery out the rest of the way.
You could try and weaken the adhesive with >97% isopropyl alcohol. But yes, the battery is indeed firmly glued in place
22 other people completed this guide.
4 Comments
Hat super geklappt, danke! Zwei wichtige Dinge - NFC Antenne ist schwer von Batterie zu lösen- müsste gleich bei Akku mit beschrieben sein und bei Schritt 7 oder 11, dass man noch eine Steckverbindung lösen muss (verklebt!) und übertragen muss. Hat geklappt, danke Euch - eure tools sind super dazu!
Danke allehoffis für dein Feedback. Freut mich, dass alle so weit geklappt hat. Ja, die NFC Antenne klebt da gut dran. Im separaten Akku-Guide ist darauf hingewiesen, dass sie schwer zu lösen ist. Vlt kommt hier auch noch eine Notiz dazu. In Schritt 6 wird die ZIF Verbindung getrennt. Ist es das, was du meinst mit “verklebt”?
Hat alles super geklappt, danke für diese Anleitung
El celular no tiene ese tipo de tapa es como sellada, que debo hacer para saber si es por la pila que no agarra carga porxa
maguada1106 - Reply
Wenn man langsam langsam arbeiten und vorsichtig ist, dann kein problem gibt es.Ich hätte keine Problemen zu öffnen.Das ist sehr leicht.
Athanasios Georgopoulos - Reply
