Huawei P10 Lite Charging Board Replacement
  1. Huawei P10 Lite Charging Board Replacement, Back cover: step 1, image 1 of 3 Huawei P10 Lite Charging Board Replacement, Back cover: step 1, image 2 of 3 Huawei P10 Lite Charging Board Replacement, Back cover: step 1, image 3 of 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
    Mit dem Saugnapf die Rückseite anheben hilft ungemein…
    Matthias Eberle - Reply
    Had to use blue wedge tool to wedge open bottom plate from the rim part in order to then use the tip of the blue opening pick under the back plate to then cut the glue. It’s like placing a pie server or knife under the plate once there’s a gap between the rim and the back plate.
    Jane - Reply
    Be careful, there’s a cable to fingerprint sensor, very close to the edge (see pictures below)… It’s very easy to cut it through with the pick, as I just learned :)
    dambig - Reply
  2. Huawei P10 Lite Charging Board Replacement: step 2, image 1 of 3 Huawei P10 Lite Charging Board Replacement: step 2, image 2 of 3 Huawei P10 Lite Charging Board Replacement: step 2, image 3 of 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Charging Board Replacement: step 3, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 3, image 2 of 2
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
    Schritt 3 und 4 kann man sich komplett sparen. Wozu auch. Kann gleich mit Schritt 5 weitergemacht werden, zuvor einfach das Flachbandkabel vom Fingerabdrucksensor an der Rückabdeckung abklemmen und fertig.
    Bobby mcgee - Reply
    There are four silver screws and two black to be removed.
    Jane - Reply
    Translate what Bobby mcgee said:
    Step 3 and 4 can be completely ignored. What for? You can continue with step 5, just disconnect the ribbon cable from the fingerprint sensor on the back cover and you're done.
    Antonio Sun - Reply
    However, the reason step 3 and 4 should not be skipped is Step 6 — Use an iOpener to loosen the adhesive beneath the battery. I.e., the adhesive cannot be easily removed without heat, however, that heat might damage the electric chips. Thus they’d better be removed first.
    Antonio Sun - Reply
  4. Huawei P10 Lite Charging Board Replacement: step 4, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 4, image 2 of 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
    Welchen Klebstoff soll man verwenden?
    josef navratil - Reply
    Hallo Josef,
    sollte bei deinem Ersatzteil kein Klebstoff oder Klebeband dabei gewesen sein, kannst du dünne Streifen Doppelseitiges Klebeband verwenden. Es gibt für das Huawei P10 Lite auch schon zugeschnittene Klebestreifen zu erwerben, hierbei gilt aber je nach Händler Rezessionen zu lesen, ob die Klebestreifen auch wirklich halten.
    Dominik Schnabelrauch -
    Note that there is a copper-colored sticker to lift up near the flat cable connected from the phone the finger pad. Lift the main board plate (shield) up SLOWLY from the camera side to the other end as the plate is wedged in place.
    Jane - Reply
    what adhesive is recommended? thanks
    darren - Reply
    Hi darren,
    pre-cut adhesive would be the best solution if you can source it. Otherwise a two-sided adhesive tape or carefully used E6000 adhesive glue will be your friend.
    Tobias Isakeit -
  5. Huawei P10 Lite Charging Board Replacement, Battery Disconnection: step 5, image 1 of 3 Huawei P10 Lite Charging Board Replacement, Battery Disconnection: step 5, image 2 of 3 Huawei P10 Lite Charging Board Replacement, Battery Disconnection: step 5, image 3 of 3
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
    Very gently lift the silver connecter that was under the battery connecter plate and is at the end of the orange battery cable with the flat end of the spudger as indicated.
    Jane - Reply
  6. Huawei P10 Lite Charging Board Replacement, Loudspeaker / Vibration Motor: step 6, image 1 of 1
    • Remove the seven Philipps #000 screws.
  7. Huawei P10 Lite Charging Board Replacement: step 7, image 1 of 3 Huawei P10 Lite Charging Board Replacement: step 7, image 2 of 3 Huawei P10 Lite Charging Board Replacement: step 7, image 3 of 3
    • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
    • Grab the loudspeaker unit and remove it.
  8. Huawei P10 Lite Charging Board Replacement: step 8, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 8, image 2 of 2
    • Use an iOpener to loosen the glue under the vibration motor.
    • Remove the vibration motor.
  9. Huawei P10 Lite Charging Board Replacement, Charging Board: step 9, image 1 of 2 Huawei P10 Lite Charging Board Replacement, Charging Board: step 9, image 2 of 2
    • Use the flat end of a spudger to disconnect the interconnect cable.
    • Use tweezers to disconnect the antenna cable.
  10. Huawei P10 Lite Charging Board Replacement: step 10, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 10, image 2 of 2
    • Use an iOpener to loosen the adhesive under the charging board.
    • Remove the charging board.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
5 other people completed this guide.
202,516 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,718 Guides authored
3 Comments
thanks and very nice
mj41574 - Reply
thanks to all team
mj41574 - Reply
p10 lite charging ic change daigram
mj41574 - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 51
All Time: 9,708
