Introduction
Use this guide to replace the back cover of your Huawei P10 Lite.
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
Flip the rear cover over to the right side of the phone.
Use a pair of tweezers to remove the sticker.
Remove the two Phillips #00 screws.
Remove the four 2.5 mm Phillips #00 screws.
Use tweezers to remove the mainboard shield.
Use the flat end of a spudger to disconnect the finger print sensor flex cable.
