Introduction
Use this guide to replace a worn-out or dead battery in your Huawei Honor 8.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Remove these Phillips #00 screws securing the midframe bezel:
Eight screws with 3.5 mm length
Eight screws with 2.9 mm length
Some screws might be covered with a tamper proof sticker.
Use a pair of tweezers to lift the black adhesive pull tab off of the top right corner of the battery.
Use a pair of tweezers to pull out the adhesive strip.
Apply a heated iOpener to the screen for at least two minutes to loosen the adhesive beneath the battery.
Display flex cable
Interconnect flex cable
Tool used on this step:Plastic Cards$2.99
Insert an opening pick or a plastic card under the battery where the adhesive strip was located.
Slide along the right side of the battery to cut the remaining adhesive.
Carefully pry up the right side of the battery to loosen the adhesive.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
23 other people completed this guide.
11 Comments
If you use isopropyl alcohol to dissolve the adhesive and remove the battery make sure it doesn’t go towards the screen (as the phone is likely going to be facing down) and that it dries completely before closing up the phone again.
I made the mistake of leaving the phone - although still opened - face down overnight and the alcohol seems to have gotten into the screen, causing bubbles and discoloring on the screen.
Thank you very much for this guide, great help! I also changed the usb port and had to watch the guide for that also :) Took some more time for a firt timer hehe, Also I did not have the pre cut adhesive, only 3 mm. I will probably find one and order it.
Very good guide, thanks a lot! I didn’t have the iOpener, so, I used very hot water in a ziplock bag and it worked great.
Very good guide, but actually, I didn’t even need to remove the circuit board. With enough warmth from the iOpener on the display side and cautiously working with all the picks, I was able to remove the battery right after removing the middle frame.
Thanks for this excellent guide! I succeeded in changing the battery in my phone. This was my first time opening up a phone so I’m even more pleased that it went so well. For the tools, I used things that I had on hand (suction cup from a bathroom hook, regular tweezers, thin cut up plastic card to make picks, hair dryer) and they all did the job. However the “picks” I used were not sturdy enough, which made it harder to cut the adhesive. If I did this again I would cut up a thicker card, or just buy some picks.
Guida ben fatta, qualche consiglio su quale adesivo usare per richiudere lo smartphone?
Ciao @lucaorl Ti consiglio di ordinare il Fix kit batteria, che include anche un foglio adesivo pretagliato (Huawei HB366481ECW Battery), oppure questo adesivo pretagliato da solo (Tesa 61395 Tape) Buona riparazione!
