Introduction
Follow this repair guide if you have problems with the brightness sensor in your device
  1. Remove back cover
    • Remove back cover
  2. Remove battery
    • Remove battery
    • With the help of a Phillips screwdriver, remove the 9 side screws, one is located under the adhesive
    • With the help of a thin tool, pry up the side joints to remove the central body
    • Unhook the display connector
    • Unclip the touchscreen connector
    • Unclip the brightness sensor connector
    • Unhook the connector that connects the motherboard to the dock
    • With the help of a thin tool, uncouple the mother board interlocked on the plastic hooks
    • Remove motherboard
    • With the help of a heat source of the tweezers remove proximity and brightness sensor by replacing it with a new one
To reassemble the device, follow these instructions in reverse order.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Smilzo
5,459 Reputation
28 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 116
