Huawei Ascend G610 Display Assembly Replacement
  1. Huawei Ascend G610 Display Assembly  Replacement, Display Assembly: step 1, image 1 of 1
    • Remove the back cover.
  2. Huawei Ascend G610 Display Assembly  Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. Huawei Ascend G610 Display Assembly  Replacement: step 3, image 1 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 3, image 2 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 3, image 3 of 3
    • With the help of a cross-head screwdriver, remove the 9 side screws that secure the back cover.
    • Note: 1 of these screws is covered by an adhesive label.
    • Remove the central screw next to the SIM card slot. Note: it's the shortest screw.
  4. Huawei Ascend G610 Display Assembly  Replacement: step 4, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 4, image 2 of 2
    • Disconnect the display connector.
  5. Huawei Ascend G610 Display Assembly  Replacement: step 5, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 5, image 2 of 2
    • Disconnect the ambient light sensor.
  6. Huawei Ascend G610 Display Assembly  Replacement: step 6, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 6, image 2 of 2
    • Unplug the touch screen connector.
  7. Huawei Ascend G610 Display Assembly  Replacement: step 7, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 7, image 2 of 2
    • Unplug the connector that joins the two boards.
  8. Huawei Ascend G610 Display Assembly  Replacement: step 8, image 1 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 8, image 2 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 8, image 3 of 3
    • Unplug the main motherboard that is secured at 3 points.
  9. Huawei Ascend G610 Display Assembly  Replacement: step 9, image 1 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 9, image 2 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 9, image 3 of 3
    • With the help of a heater, heat the board attached with double-sided adhesive tape.
    • With a thin tool, gently pry underneath the adhesive until it is fully detached.
  10. Huawei Ascend G610 Display Assembly  Replacement: step 10, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 10, image 2 of 2
    • Remove the housed microphone.
  11. Huawei Ascend G610 Display Assembly  Replacement: step 11, image 1 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 11, image 2 of 3 Huawei Ascend G610 Display Assembly  Replacement: step 11, image 3 of 3
    • Using the phone for leverage, remove the flat volume keys and turn off the device.
  12. Huawei Ascend G610 Display Assembly  Replacement: step 12, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 12, image 2 of 2
    • Remove the speaker.
  13. Huawei Ascend G610 Display Assembly  Replacement: step 13, image 1 of 2 Huawei Ascend G610 Display Assembly  Replacement: step 13, image 2 of 2
    • Remove the ambient light sensor.
  14. Huawei Ascend G610 Display Assembly  Replacement: step 14, image 1 of 1
    • Remove the unique adhesive label on the phone.
  15. Huawei Ascend G610 Display Assembly  Replacement: step 15, image 1 of 1
    • Now, reassemble the pieces on the new display assembly with the frame and touch screen by reversing the steps of this guide.
To reassemble the device, follow these instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
it en
100%
Ben Johnson is helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,267 Reputation
39 Guides authored
4 Comments
Hi. Do you follow this procedure to replace a shattered screen? Where can I get the specialised little plastic tools designed to do this? Interesting. Thank.J.
jessemark05 - Reply
hello, generally the tools are found together with the new display that you buy.  otherwise you can buy them online or at ifixit shop
Smilzo -
Got the tools needed,thanks for reply. Do I have to follow this complete procedure just to replace the screen? Jesse.
jessemark05 - Reply
yes, this is the procedure to replace the complete frame display
Smilzo -
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,330
