Disconnect the printer from power source and then open the photocopy/scanner door.
You will see four screws on the ends. Unsrew them with the necessary equipment.
Carefully lift the top of the printer. Lift he back first near the paper tray to expose the interior of the printer.
Unscrew the three screws one on the upper side on the left and two that are in the middle of the catridge belt mover.
Remove it to expose the cables.
As you can see in this case my printer has broken cables. The yellow, green and black cables are broken.
Replaces the cables. It is also important to check the sensor cable.
After replacing any broken cables, reassemble your printer starting with the printer mover rail.
Screw it tightly into place.
Screw the motherboard into place tightly.
Ensure everything is in place.
Your printer should work just fine.
2 other people completed this guide.
2 Comments
You are much welcome. Glad to know I was able to help.
