Introduction
If the drum in your dryer no longer turns but the motor still hums, the drive belt has likely stretched, cracked, or snapped. Replacing the belt restores proper drum rotation and will keep your laundry cycles running correctly. This guide walks you through the full belt replacement on a condenser-type dryer, including the disassembly needed to create working space and the precise routing over the motor pulley and tensioner.
Step 2 Remove condensate container
Pull the condensate container straight out of its slot.
Remove the two coarse-thread screws located behind the container.
Step 3 Detach service side cover screws
Unscrew all rear screws that secure the service side cover to the cabinet.
Lift the cover slightly and slide it downward to release it.
Remove the corner screw and four additional screws along the edge.
Step 4 Remove the side panel
Remove the four screws along the lower edge of the side panel from underneath the dryer.
Tilt the panel outward then lift it away to expose the internal components.
Step 5 Inspect thermal fuse area
Check the thermal fuse near the motor to ensure it has not tripped.
Step 6 Remove condenser fan screws
Use an angled Phillips screwdriver to remove the two deeply recessed screws holding the condenser cooling fan.
Step 7 Release fan housing and disconnect wiring
Press the plastic locking tabs on both sides of the fan housing and pull the assembly outward.
Disconnect the keyed motor connector to free the wiring harness.
Step 8 Remove motor mounting screws
From beneath the dryer, remove the four Torx 25 screws securing the motor bracket.
Step 9 Extract the motor assembly
Twist and pull the freed motor out of the cabinet through the opened space.
Step 10 Create clearance for belt removal
Unscrew and remove the long spacer rod running along the cabinet side.
Remove the two screws securing the condensate container bracket on the rear panel.
Loosen the four side-panel screws so the panel can flex outward slightly.
Step 11 Free the rear drum support
Loosen and remove the large axle nut anchoring the drum to the rear panel.
Pull the rear panel rearwards to create a gap big enough to pass the belt.
Step 12 Flex the front and lower assemblies
Remove screws and cable ties on the opposite side to allow the front panel to move.
Unscrew the two small screws holding the front brace rod.
Remove five screws securing the lower plastic condensate chamber.
Gently flex the assemblies apart until the belt can slip through the opening.
Step 13 Install the new belt
Slide the old belt off the drum and discard it.
Feed the new belt over the drum shaft and around the drum through the created gap.
Rotate the drum by hand to seat the belt evenly all around.
Step 14 Seat the drum and bearing
Lift the drum slightly and guide the front felt ring and rear bearing into place.
Check alignment through inspection holes while centring the drum.
Reinstall and tighten the drum hub bolt while supporting the drum weight.
Step 15 Tighten fasteners and brackets
Refit the side-panel screws and secure the condensate support bracket with its two screws.
Step 17 Refit motor and route belt
Loop the belt onto the motor pulley and around the tensioner wheel.
Hold the tensioner and push the motor shaft diagonally into its mount.
Make sure the tensioner pin seats fully in its plastic housing.
Install and tighten the four Torx 25 screws from underneath, returning the motor to its original position.
Step 18 Reconnect wiring and test belt tracking
Plug the motor harness connector back into its socket.
Step 19 Secure airflow housing and deep screws
Seat the plastic airflow housing fully into all grooves to prevent leaks.
Reinstall the two deep fan screws using the angled screwdriver.
Step 20 Reassemble outer panels
Refit the rear panel and tighten all screws while checking for rubs or squeaks.
Clean, position and secure the service side cover with all its screws.
Reinstall the top lid and any remaining panels to close the cabinet.
The drive belt is now installed, the drum spins freely, and the dryer is reassembled. Keep an ear on the machine during its first full load to verify quiet, steady operation. Regularly inspecting the belt for cracks will help you catch wear before it stops the drum again.
